It is currently Fri Oct 16, 2026 1:45 pm
Post Posted: Sat Oct 23, 2010 10:08 am
i was always pretty sure that g16bs are non interference engines?
for this reason i have been putting of the cam belt. but if somebody proves they are not then id better get around to doing it.
Post Posted: Sat Oct 23, 2010 10:51 am
All factory G series motors are free spinners AFAIK.
I've seen a G 16B break a timing belt and I can assure you it was a free spinner because it took us about 6 hours to figure out why it wouldn't run....
Post Posted: Sat Oct 23, 2010 11:19 am
hmmm ok, this is good to know. i have a haynes manual, i have had a look but cant find anything info on it being a interference engine or not. any ideas on where i can?
i was always told that it was just the G13 engines that were non-interference engine.
Mitch
Post Posted: Sat Oct 23, 2010 6:51 pm
Just googled the question and every post says the same thing....
Non interference
Post Posted: Sat Oct 23, 2010 9:29 pm
The only G engine which is an interference engine is the G13B.
I want my old sig back :(
Post Posted: Sat Oct 23, 2010 11:40 pm
ben - g13b or g13bb? or both?
Post Posted: Sun Oct 24, 2010 12:51 am
g13b is interferance i think the rest arnt.
Post Posted: Sun Oct 24, 2010 2:49 am
g16b is interference hate to say people ....
Post Posted: Sun Oct 24, 2010 3:44 am
G13B...
Cos of the twin cam.
Vehicle: 1987 sierra tray back buggy
Post Posted: Sun Oct 24, 2010 3:56 am
Ben_Sierra wrote:
G13B...
why Because of the twin cam?
Not disputing it just asking why.
Post Posted: Sun Oct 24, 2010 5:27 am
I dunno if its just bacause its a twin cam, but the twin cam head is an interference design...
Post Posted: Sun Oct 24, 2010 5:49 am
can anyone explain why Suzuki made the g13b twin cam head interference design. i find it odd that the rest of the series is free running but they decided to do it this way with the 13b. i dont see that the fact it is twin cam should dictate this design change or am i missing something?
Post Posted: Sun Oct 24, 2010 5:53 am
more valves, higher compression, valves get closer to teh piston tops
Post Posted: Sun Oct 24, 2010 5:54 am
this explains it well:
No Valve/Piston Interference
and this seems pretty good at telling you if its interference or not: http://www.gates.com/part_locator/index ... on_id=3598
g13a - non-interference
g16a - non-interference
g16b - INTERFERENCE
theres no real data on the jimny, but if that trend flows through would mean if its a 16 valve engine, its interference - which would makes sense given the limited space in there =)
Post Posted: Sun Oct 24, 2010 5:57 am
oh k higher compression engine that would explain it, cool thanks for the explanation.
yeah i know what is meant by interference and non interference. dont know anything about the g13b so i didnt realize it was higher compression.
Post Posted: Sun Oct 24, 2010 5:58 am
what makes you say that? as everyone else is saying its not...even google!
Post Posted: Sun Oct 24, 2010 6:04 am
gates says it is, most multi valve engines are
Post Posted: Sun Oct 24, 2010 6:08 am
ive worked on more suzuki engines than most people have had hot dinners , g13b is interference , g16b is interference ..
Post Posted: Sun Oct 24, 2010 6:09 am
My G16B is not interference... I've wound it over by hand without cam belt fitted a few times..
Post Posted: Sun Oct 24, 2010 6:13 am
are you certain at least 1 inlet valve is fully open? and now not bent :)
Users browsing this forum: No registered users and 208 guests
