| g 16bs free running http://auszookers.com/forum/viewtopic.php?f=5&t=16165 |
| Author: | BJPK [ Sat Oct 23, 2010 10:08 am ] |
| Post subject: | g 16bs free running |
i was always pretty sure that g16bs are non interference engines? for this reason i have been putting of the cam belt. but if somebody proves they are not then id better get around to doing it. |
| Author: | Gwagensteve [ Sat Oct 23, 2010 10:51 am ] |
| Post subject: | Re: g 16bs free running |
All factory G series motors are free spinners AFAIK. I've seen a G 16B break a timing belt and I can assure you it was a free spinner because it took us about 6 hours to figure out why it wouldn't run.... Steve. |
| Author: | shandy92 [ Sat Oct 23, 2010 11:19 am ] |
hmmm ok, this is good to know. i have a haynes manual, i have had a look but cant find anything info on it being a interference engine or not. any ideas on where i can? i was always told that it was just the G13 engines that were non-interference engine. Mitch |
| Author: | 89_tintop [ Sat Oct 23, 2010 6:51 pm ] |
Just googled the question and every post says the same thing.... Non interference |
| Author: | Ben_Sierra [ Sat Oct 23, 2010 9:29 pm ] |
The only G engine which is an interference engine is the G13B. |
| Author: | alien [ Sat Oct 23, 2010 11:40 pm ] |
ben - g13b or g13bb? or both? |
| Author: | jonno_racing [ Sun Oct 24, 2010 12:51 am ] |
g13b is interferance i think the rest arnt. |
| Author: | losfer [ Sun Oct 24, 2010 2:49 am ] |
g16b is interference hate to say people .... |
| Author: | Ben_Sierra [ Sun Oct 24, 2010 3:44 am ] |
alien wrote: ben - g13b or g13bb? or both?
G13B... Cos of the twin cam. |
| Author: | matty87 [ Sun Oct 24, 2010 3:56 am ] |
Ben_Sierra wrote: alien wrote: ben - g13b or g13bb? or both? G13B... Cos of the twin cam. why Because of the twin cam? Not disputing it just asking why. |
| Author: | Ben_Sierra [ Sun Oct 24, 2010 5:27 am ] |
I dunno if its just bacause its a twin cam, but the twin cam head is an interference design... |
| Author: | matty87 [ Sun Oct 24, 2010 5:49 am ] |
can anyone explain why Suzuki made the g13b twin cam head interference design. i find it odd that the rest of the series is free running but they decided to do it this way with the 13b. i dont see that the fact it is twin cam should dictate this design change or am i missing something? |
| Author: | royce [ Sun Oct 24, 2010 5:53 am ] |
more valves, higher compression, valves get closer to teh piston tops |
| Author: | alien [ Sun Oct 24, 2010 5:54 am ] |
this explains it well:
No Valve/Piston Interference
Valve/Piston Interference and this seems pretty good at telling you if its interference or not: http://www.gates.com/part_locator/index ... on_id=3598 g13a - non-interference g16a - non-interference g16b - INTERFERENCE theres no real data on the jimny, but if that trend flows through would mean if its a 16 valve engine, its interference - which would makes sense given the limited space in there =) |
| Author: | matty87 [ Sun Oct 24, 2010 5:57 am ] |
oh k higher compression engine that would explain it, cool thanks for the explanation. yeah i know what is meant by interference and non interference. dont know anything about the g13b so i didnt realize it was higher compression. |
| Author: | shandy92 [ Sun Oct 24, 2010 5:58 am ] |
losfer wrote: g16b is interference hate to say people ....
what makes you say that? as everyone else is saying its not...even google! |
| Author: | royce [ Sun Oct 24, 2010 6:04 am ] |
gates says it is, most multi valve engines are |
| Author: | losfer [ Sun Oct 24, 2010 6:08 am ] |
ive worked on more suzuki engines than most people have had hot dinners , g13b is interference , g16b is interference .. |
| Author: | want33s [ Sun Oct 24, 2010 6:09 am ] |
My G16B is not interference... I've wound it over by hand without cam belt fitted a few times.. |
| Author: | royce [ Sun Oct 24, 2010 6:13 am ] |
want33s wrote: My G16B is not interference... I've wound it over by hand without cam belt fitted a few times..
are you certain at least 1 inlet valve is fully open? and now not bent |
