It is currently Fri Oct 16, 2026 4:07 pm
Vehicle: 93 Sierra
Post Posted: Sat Oct 23, 2010 12:23 pm
Fitting up a just_cruising transfer lift kit at the moment ... +40 above standard, like this photo I've pinched from an old post of his. Have got a Roctoy ring on there too with 2" BL and can't get the passenger side mount in ... the Roctoy ring hits the driver's side of the tunnel about 5mm shy of being able to slide in the smaller of the two lift blocks.
Can I safely shave 5-10mm off the mount on that side, 'clocking' the transfer down slightly on the passenger side? Would prefer to do that that take meat off the ring.
Also didn't realise that I should have marked the flanges when I removed them from the transfer. I take it this isn't really likely to cause too many problems?
just_cruizin wrote:
Post Posted: Sat Oct 23, 2010 1:10 pm
dont forget the box will need some clearance too - it moves around a bit on its mounts =)
Post Posted: Sat Oct 23, 2010 1:25 pm
Cant use a hammer ? 5-10 mm should be hammerable.
Post Posted: Sat Oct 23, 2010 1:42 pm
mmm... hammer
he's right you know - if at first you don't succeed, find a bigger hammer.
Vehicle: 93 Sierra
Post Posted: Sat Oct 23, 2010 1:51 pm
Yeah hammer it is. Actually managed to get it in there once I tightened up the driver's side bolts, pulling that side down some. So will give it a gentle tap with Mr Persuasion and should be dandy =)
Post Posted: Sat Oct 23, 2010 8:03 pm
hammer time 8)
Post Posted: Sat Oct 23, 2010 11:10 pm
i managed to get mine in with the full 40mm and 2inch bl with ring..
wish i didnt! it was so noisey!! hard on the floor!..
give your ring around 20mm of clearance....
Post Posted: Sun Oct 24, 2010 6:19 am
i have 50mm BL with 50mm Translift.
Hammer floor/tunnel corners and slight shaving of the ring is needed.
Users browsing this forum: Google [Bot] and 223 guests
