It is currently Thu Oct 01, 2026 8:07 pm
Post new topic Reply to topic  [ 29 posts ]
Vehicle: 94 Vitara LWB G16b
Post Posted: Sun Oct 24, 2010 8:33 pm
Hi All,
Anyone able to tell me if it is worthwhile buying heavy duty igniton leads?
Supercheap can get a set for the G16b for $80 standard (Bosch - B4261i ) or $117 'heavy duty' (Top Gun - TG4489) or NGK (RC-SE14) for $90
Anyone know what the difference is and if it's worth it?
http://www.bosch.co.nz/content/language ... eb_ready(1).pdf
http://www.topgunleads.com.au/catalogue2008.pdf
Chris
Post Posted: Sun Oct 24, 2010 8:39 pm
I have always bought h/duty leads. IMO it gives a better spark and a bit more longevity from the leads. Like I said my opionion though, some may have differing opinions :wink:
Post Posted: Sun Oct 24, 2010 8:42 pm
I'd run Bosch way before that Top Gun crap.
Post Posted: Sun Oct 24, 2010 8:44 pm
x2...bit of a contradiction, but I have always had leads made up at QLD ignition leads. The last set I bought for the sierra were about $90 8)
Post Posted: Sun Oct 24, 2010 10:00 pm
ok, thanks guys,
what about NGK? Anyone know if they are better than the Bosch? I have no idea if they are claimed to be heavy duty? Anyone able to tell?
RC-SE14 - $90 online
94 Vitara LWB G16b
Post Posted: Sun Oct 24, 2010 10:31 pm
Jas, why is that, I have top gun, lowest impedance I can find.
Post Posted: Sun Oct 24, 2010 10:51 pm
eXc450 wrote:
ok, thanks guys,
Seems like both the NGK and Bosch are stainless braided, so I can't see much difference in them except $10-20 price.
I'll get the NGKs cause I have never had a bad experience with NGK spark plugs, but I did with bosch plugs and fuel pump.
Post Posted: Sun Oct 24, 2010 11:47 pm
Standard leads are fine, Heavy Duty i suppose are nice, but why pay the extra?
Most cars with reasonable performance mods can get away with a 7-8mm lead EASILY
Whilst most aftermarket leads are a common 10mm which is rediculous overkill for any Zook i could ever think of
Top Gun aren't a bad brand at all, infact they're reasonbly reputable.
Bosch by comparison are yes, well known.. But they aren't anything special.
Bosch make some of the worst spark plugs known to man, and suck horridly at making a competitively priced O2 Sensor (Atleast for Hondas, unsure about Suzi)
They're an OEM replacement parts dealer, it "meets" OEM standard, and in rare cases exceeds.
My vote is NGK or Champion, those are great easily sourced brands for ignition products
Vehicle: SJ80, SE416
Post Posted: Mon Oct 25, 2010 12:41 am
I don't know which is better and I don't care since I have Top Gun on one of my Sierras and Bosch on the other and there is no noticable difference in performance, but has anyone else had the drama of pulling a lead off while the car is running (to troubleshoot) only to have the boot over the end come off on the Top Gun leads and give you a nice electric shock. My Bosch leads don't have that problem...
I will definitely buy Bosch next time!
Post Posted: Mon Oct 25, 2010 12:47 am
holy moly you fellas get shafted on ya parts. the last lot of tune up and
service stuff i bought i got change from $100
thats for 15w40 oil, oil filter, fuel filter, plugs,leads(top gun 8mm),cap and rotor.
Post Posted: Mon Oct 25, 2010 1:03 am
Absolutely terrified of 45,000 volt kiks, always use a lead puller pliers.
Shep, how on earth do you get that, my oil is near that much, was this from a mate who watched it fall off the back of a truck.
Post Posted: Mon Oct 25, 2010 1:08 am
Not all of us run fancy fully synthetic oil in our zooks...
I want my old sig back :(
Post Posted: Mon Oct 25, 2010 1:16 am
lol yea I understand that, but with all shep can get for under a ton, must be woolies grade oil, even then I recon as that is amazingly cheap for all.
Post Posted: Mon Oct 25, 2010 2:40 am
thats with a baldwin filter and Valvoline engine armor 15w40, the leads are a little under $40 for the kit, oh and ya get the swift kit cos it is cheap.
from memery
baldwin oil filter $6
ryco fuel filter $5
bosch cap $10
bosch rotor $6
oil $23
lead kit $40
another $40 services both diffs and the gearbox and transfer as well.
Post Posted: Mon Oct 25, 2010 7:40 pm
If you willing to spend that much. Look into leads from ice ignitions in Clayton.
Post Posted: Mon Oct 25, 2010 8:24 pm
Most of my cars run Bosch leads without problems...
I can't remember how many faulty TopGun leads I've replaced over the years.
Bigger diameter leads are a bit of a joke........ My 2Rz EFI Hiace runs puny little 4 or 5mm leads as do most new cars... They have done 220,000km without issue.
My ute runs MSD Superconductor leads which are only 8.5-9mm or so even with a 7AL2 ignition system.
Cut open a TopGun 10mm lead and you'll find the core is the same as a 6mm lead but it has more rubber/plastic around it which does SFA.
Post Posted: Tue Oct 26, 2010 12:51 am
I have no idea there, mine are 8mm. I go by the impedance, as far as I understand, there is less leakage with thicker leads, but once past a point, its all show n extra dollars.
Post Posted: Tue Oct 26, 2010 1:42 am
yes, well the thicker leads would stop them shorting, that is why mine are still running (lots of electrical tape) but I had to re-tape them the other day, so I thought I'd buy new ones, and keep these taped ones as spares.
94 Vitara LWB G16b
Vehicle: LPG 1.6 Sierra
Post Posted: Sat Jul 09, 2011 6:52 am
OK, my leads are shot after only 15000K travelled... just swapped them out for the shitty looking ones on my spares motor and it's a night and day difference. I finally found the gremlin in my electrical system... damn you LPG! Not really, I love you LPG
Anyway, I can't afford to replace leads every 6 months so I wanna sort a long term fix. The standard 8mm Bosch Super Sports aren't enough so it's time for overkill - gonna buy some 10.5mm ignition cable off Eagle Products and make my own to last a loooong time.
Just a matter of sourcing plug connectors and boots for the job... can anyone point me in the right direction?
Vehicle: LJ20 LJ50
Post Posted: Sat Jul 09, 2011 7:04 am
Take a tape measure and a multi meter to the wrecking yard. you can get a set of great leads for $10.00 plus you can get a pocket full of bolts, fuses and relays as well. hell cut the relay holders out of the wiring loom too. and if you are tight enough you can get bulbs for tail lights as well and even headlight bulbs if you are super stingy
Camels have nice toes
Post Posted: Sat Jul 09, 2011 12:26 pm
Lets put it this way, you aren't building a racecar, any brand of new leads im sure will do the job, and as long as they meet the OEM Requirements they will be fine.
Stocker
Post Posted: Sat Jul 09, 2011 12:30 pm
More often than not these thick 'super leads' 7,8,10,12mm what ever correspond to the total thickness of the leads. Core conducting material is usually the same diameter within them.
Lil Foot!
http://tiny.cc/gtsw1
Vehicle: 92 Suzuki Sierra
Post Posted: Sat Jul 09, 2011 12:48 pm
A man after my own heart but i don't think of it as being stingy its more about being Carbon Neutral.. (we used to call it recycling but marketing has changed its tune :P )
i get nuts, bolts, fuses and yes bulbs... not sure i would go as far as leads. Generic bosch leads are $6 each at supercheap. i figured ACTUALLY buying a set of 5 each on average of 6 months to a year for $30 would be better than buying really snazzy leads for $100+ and then not replacing them again.
-Santos
Post Posted: Sat Jul 09, 2011 1:28 pm
Not in my case, but like I said i'm running LPG - different requirements. The Bosch 8mm Super Sports are supposed to last 5 years/100K on a petrol donk... I got no more than 6 months and 15K before they turned bad, for the last two months they've been unbearable, but I've been pointing fingers at spark plugs, ignition modules and coils wondering what hell happened to my spark - it was the leads all along.
These would be ideal http://www.eagleproducts.com.au/product ... or_lpg.php , but doubt i'll find a set for a G16B. Time to get my Maguyver on and make my own
Post Posted: Sat Jul 09, 2011 1:51 pm
would leads cause a miss when cold or is that more a fuel/carby problem? (g16a)
Post Posted: Sat Jul 09, 2011 1:52 pm
i told you it was leads and you were all 'nyer nyer nyer theyre not that old, blah blah blah" =) lol
Post Posted: Sat Jul 09, 2011 2:13 pm
They were too new, I had faith they were OK :lol: 1% wiser to LPG now :crazy:
Symptoms of bad leads:
Rough as hell idle, random misfires, hesitation when you put the foot down, top speed -10%.
Post Posted: Sat Jul 09, 2011 2:30 pm
thats what you get for having faith =) lol
Post Posted: Sat Jul 09, 2011 10:44 pm
Che, try these, they good enuf for open fuel rails.
http://www.magnecor.com/magnecor1/main.htm
Users browsing this forum: Google [Bot] and 151 guests
