It is currently Sun Oct 18, 2026 5:35 pm
Post Posted: Mon Oct 25, 2010 3:45 am
how do u drain oil from it?
mine has recently got alot of plaay.
and when ya turn its free then hard for abit then frees up again then hard.. same cycle both ways. no idea whats goin on.
If in doubt power out!
Post Posted: Mon Oct 25, 2010 5:10 am
i had the same problem with mine had no adjustment left in it so put a new one in it drives like a new car now no more wandering all over the road
Post Posted: Mon Oct 25, 2010 5:16 am
I have 5 or so spares if you wanted to grab one to swap in.
Post Posted: Mon Oct 25, 2010 5:34 am
I stumbled across this the other day
http://perth.gumtree.com.au/c-Cars-Vehi ... Z237826983
$50 for a fucked steering box.....that seems fair :roll:
Post Posted: Mon Oct 25, 2010 5:40 am
tanshi, where abouts are you mate?
Post Posted: Mon Oct 25, 2010 6:01 am
i have one from a nt im selling, i think they are the same as the wts?
It moves freely and seems ok. PM me if interested
Post Posted: Mon Oct 25, 2010 6:17 am
if anyone has a spare one around redcliffe?
Post Posted: Mon Oct 25, 2010 6:18 am
http://auszookers.com/index.php?name=Fo ... ic&t=15379
he's got 3 spare one's.. :P
Post Posted: Mon Oct 25, 2010 7:02 am
You might have more than one problem there ando.
A) If you have adjusted up the box and it's still loose around straight ahead (or is loose around straight ahead and then goes tight once adjusted) then the box is a throw away. Suzuki offer no rebuild parts for the steering box.
B) It could be possible you have a seized steering shaft uni. This will cause the loose/tight/loose/tight result. The steering shaft unis aren't replaceable, so you'll need a new shaft.
Pull the steering shaft and make sure the unis are free in all directions. It would be annoying to replace the steering box and end up with no play but still have the tight/loose/tight steering feel.
Post Posted: Mon Oct 25, 2010 7:07 am
Looked at your steering uni?? I had very similar symptoms with mine, replaced the uni and it is now great. The uni was completely seized on one of it's movements, IE would only move horizontally not vertically and vise versa. Could be worth a look, a lot cheaper than a. Steering box replacement also :wink:
Post Posted: Mon Oct 25, 2010 7:08 am
Damn i type slow. If you struggle to find a replacement 2nd hand uni(doubt you will) try taking the uni into a drive line place to see if they can find you a replacement/alternative
Post Posted: Mon Oct 25, 2010 7:45 am
located ipswich
Users browsing this forum: No registered users and 224 guests
