It is currently Wed Nov 04, 2026 1:35 pm
Post Posted: Wed Jan 02, 2008 8:16 pm
Happy New Year to everyone at Auszookers!
I would appreciate some advice and observations from experienced Zookers...I have owned a Ford dual cab and a Patrol in the past and driven a 100 Series down Madigans Line, but have been out of the 4x4 scene for far too long.
Money is tight, so I am now considering purchasing a 98-2000 GV and would like some guidance with the following:
1. Can the GV be set up for remote are travel for 2 people i.e. I would like to re-visit the Simpson Desert (French Line etc)?
2. How does the GV perform on a trip like this fully loaded with 2 adults?
3. What fuel economy can I expect in the desert and on road (open and city)?
4. How does the Ironman suspension rate? It appears much cheaper than the OME.
5. Does the GV have a rear LSD?
6. Does anyone know of a good GV in Adelaide worth buying and what do I need to look out for?
Thanks guys and gals! Your advice is much appreciated and hopefully I can repay the board one day with some advice of my own.
Cheers!
Chilli
Post Posted: Wed Jan 02, 2008 9:15 pm
Hi chilli and welcome to Auszookers
I think a GV will do what you want just nicely, have a look at Bruces and Vitzooks threads in the members section for some ideas.
I would suggest possibly looking at later models as well, the only bugbear with the early ones is the weak alloy front diff, easilly fixed by fitting a steel diff and housing from on 03 on GV but the cost of doing it might make it more worthwile to buy one with it fitted factory
I am pretty sure 15l/100km is about normal heavilly loaded with roof rack and so on, as to suspension, OME has the runs on the board so to speak as a good package for the vitaras and is definately worth the money
Post Posted: Mon Jan 07, 2008 2:43 pm
Hey Chilli
Shouldn't be a problem - we just spent 2 weeks in Tassie (drove down from Brisbane) plenty of space for camping gear etc for 2 people, although not quite the same as the simpson.....
No problems - the manual V6 has enough power to still overtake and cruise comfortably at 110-115 kph. Thats with a roof tent fitted, and taller tyres (225/75-16)
This depended on the weather - headwinds killed us totally (tent has massive windage) - fuel consumption jumped to 15 l/100k, averaged around 11.0 l/100k over the 7500km - best was on the great ocean road without the tent, 9.1 l/100k. Around town we are averaging 11.5 l/100k.
Not sure about the desert - but on Moreton/Straddie we average around 16l/100k...thats in low range thru the tracks, and high range on the beach...
Not sure - I just have Coil spacers from Bruce adding 30mm in lift, and just added the bigger tyres - 225/75-16's which add an extra 28mm of height as well (almost 60mm in extra sidewall height!)
Unfortunately No. But air lockers are available.....
Check out car sales and the usual sites...look out for a good service history, and timing chain rattle on startup from cold...also side seals on the front diff seem to be a weak point (one of mine has just gone)
Hope this helps a bit!
James
Users browsing this forum: Google [Bot] and 90 guests
