| G16B pulleys http://auszookers.com/forum/viewtopic.php?f=5&t=16248 |
| Author: | truongski [ Wed Oct 27, 2010 12:23 am ] |
| Post subject: | G16B pulleys |
Hi fellas, I own a 97 SWB Vitara JX and I got by belts replaced yesterday by a mechanic because they were squealing like a mo-fo. Anyway, new belts on and there is a slight squeal at lowish revs (<3500rpm). A/C squeals briefly when you turn it on. I only bought the car about 6 weeks ago and it wasn't squealing then. Now, I took the car to the mechanic this morning and he said the pulleys are very shiny. I asked the mechanic about possibly getting new pulleys. He said that they probably don't make them new anymore or hard to get. Is that true? Would a set from the wreckers be sufficient? Or are there new ones available? Cheers. T-man. |
| Author: | Reubs [ Wed Oct 27, 2010 12:46 am ] |
| Post subject: | Re: G16B pulleys |
I think you need a mechanic who can adjust the belt tension properly... Usually put the belt on, tighten and check for a certain amount of deflection with a given force. |
| Author: | truongski [ Wed Oct 27, 2010 12:48 am ] |
Thanks Reubs. He is going to try to tension up the belts again today and see how that goes. |
| Author: | BlueSuzy [ Wed Oct 27, 2010 1:13 am ] |
Also wd40 helps. Yes its lubricant..but it works. |
| Author: | truongski [ Wed Oct 27, 2010 1:41 am ] |
Just had a chat to the mechanic and he says that the mob that installed the A/C has installed the compressor a little off square and that's why the belt squeals. I'll give them a call to see if they can fabricate a new bottom bracket. Thanks again for all your help lads. |
| Author: | DarkHorse [ Wed Oct 27, 2010 12:38 pm ] |
My belts started squealing on start-up a few months after I bought it. It goes away after a few seconds so I just cope with it. Where'd you get the AC done? Can I ask how much? |
| Author: | truongski [ Wed Oct 27, 2010 9:19 pm ] |
DarkHorse wrote: My belts started squealing on start-up a few months after I bought it. It goes away after a few seconds so I just cope with it.
Where'd you get the AC done? Can I ask how much? A/C was installed when I bought the car. |
| Author: | steak_knife [ Thu Oct 28, 2010 8:08 am ] |
Tell em to tighten the belt, thay have to be tight, more than any other car I've ever put a spanner to. |
| Author: | DarkHorse [ Thu Oct 28, 2010 9:51 am ] |
On that note... yours is a 97, so 2L? Anyone with a G16B with AC mind taking a photo of the belt and pulley that drives the AC compressor for me? |
| Author: | shandy92 [ Thu Oct 28, 2010 12:35 pm ] |
DarkHorse wrote: On that note... yours is a 97, so 2L?
Anyone with a G16B with AC mind taking a photo of the belt and pulley that drives the AC compressor for me? Mate, i got a/c and its 1.6l. i think i have a photo somewhere of it if not ill get one and put it up when i can. u can have/buy mine if you really really want, i have had it for about 2 yrs and used about 5 times lol. Mitch |
| Author: | truongski [ Thu Oct 28, 2010 8:51 pm ] |
BlueSuzy wrote: Also wd40 helps.
Yes its lubricant..but it works. I used WD-40 this morning. It made it worse. |
| Author: | christover1 [ Thu Oct 28, 2010 9:48 pm ] |
To my eyes that does look a bit off centre. Could be a camera angle thing. It also looks like some spacers/washers under bolts would bring it out more square?? |
| Author: | Hybrid [ Thu Oct 28, 2010 9:51 pm ] |
That's where I mounted my power steering pump. On my G16A if I remember correctly the front and back mounting faces (bolt holes on block) aren't in the same plane. If they've run a straight flat mount and bolted it to the front and back bolt holes that would kick it out of square. I would have expected it to be worse than that though. |
| Author: | DarkHorse [ Fri Oct 29, 2010 12:00 am ] |
Thanks for that truongski - I agree with christover, it does look a touch off square from that pic. Any chance of a slightly wider shot to include the pulley that drives the belt (the one just on the right edge of that photo)? Oh, and shandy92 - I've got all the parts except the drive belt, just need to suss out exactly what is already in the engine bay and what I'll need to source. Thanks anyway! |
| Author: | royce [ Fri Oct 29, 2010 12:03 am ] |
looks like it needs to come forward a groove, also looks like the adjuster is as far as it goes and should be a size smaller belt to get more tension |
| Author: | truongski [ Fri Oct 29, 2010 12:15 am ] |
royce wrote: looks like it needs to come forward a groove, also looks like the adjuster is as far as it goes and should be a size smaller belt to get more tension
At first, be put a smaller belt in there. They he swapped it out for the bigger one. What I might do, is ask him to put the smaller one back on so he can tension it up a bit better. |
| Author: | christover1 [ Fri Oct 29, 2010 8:36 am ] |
If it not straight, is there any reason belt can't be moved one v outwaRDS, PLENTY OF GROOVES SPARE? BLOODY CAPS LOCK |
| Author: | shandy92 [ Fri Oct 29, 2010 8:44 am ] |
sorry i havnt got a pic, but mine looks exactly the same as that. mines aftermarket as well, and mine is not square. mine used to squeal but i just tightened it really tight...and it stopped. i think mine is slightly more off sqaure that urs tho. not much u can do about it but just make it really tight. Mitch |
| Author: | royce [ Fri Oct 29, 2010 8:57 am ] |
Its not square cause there is no rear mount so its flexing out, ill get a pic of mine, its heaps beefier |
| Author: | shandy92 [ Fri Oct 29, 2010 9:01 am ] |
royce wrote: Its not square cause there is no rear mount so its flexing out, ill get a pic of mine, its heaps beefier
im pretty sure mine has a rear mount, ill go have a look in a sec. mine is about 10mm steel so its pretty beefed up |
| Author: | royce [ Fri Oct 29, 2010 9:02 am ] |
That was quick, look its even Sunny! |
| Author: | jdk81 [ Fri Oct 29, 2010 7:43 pm ] |
Once again Royce is on the money. |
| Author: | truongski [ Fri Oct 29, 2010 7:54 pm ] |
When you draw it up like that it's pretty bad. Royce, your bracket looks heaps better. Is yours the stock Suzuki one or a custom? How do you adjust it? |
| Author: | royce [ Fri Oct 29, 2010 8:22 pm ] |
truongski wrote: When you draw it up like that it's pretty bad.
Royce, your bracket looks heaps better. Is yours the stock Suzuki one or a custom? How do you adjust it? Aftermarket, made by a mob called TRX automotive I think, dont ring them though cause they dont make em anymore I got the last one to the left of the AC pulley youll see a bolt head and a little pulley, it moves up and down to tension the belt I have another bracket here for the same compressor but to suit no AC I would part with for the right money |
