| sierra transfer case rebuild in SE Melb http://auszookers.com/forum/viewtopic.php?f=5&t=16250 |
| Author: | andy1517 [ Wed Oct 27, 2010 12:49 am ] |
| Post subject: | sierra transfer case rebuild in SE Melb |
Guys, I have ordered some 4.9 transfer case gears from the states along with a transfer case gear supplement kit. Can anyone suggest someone to rebuild the case with the new gears for me. Im located in SE melbourne. Also what would it roughly cost? Thanks in advance, Andrew |
| Author: | Rusho [ Wed Oct 27, 2010 1:08 am ] |
| Post subject: | Re: sierra transfer case rebuild in SE Melb |
Possibly joeblow, he is a member on here. Send him a PM |
| Author: | andy1517 [ Wed Oct 27, 2010 2:49 am ] |
thanks, will have a look around on the net and try and get some prices. |
| Author: | dank [ Wed Oct 27, 2010 2:51 am ] |
i have a solid guy who has installed sierra gears before. Knows his shit and is cheap. you've already spoken to me andy but if anyone else in melbs needs a contact for gears and or diff gears, lockers, general fab then let me know. |
| Author: | andy1517 [ Wed Oct 27, 2010 3:14 am ] |
Thanks mate. Just gotta remove the transfer case now. Dropped off my engine to start building today... |
| Author: | Hybrid [ Wed Oct 27, 2010 8:51 am ] |
If you're handy enough to get the transfer out you might find you're right to do it yourself. I did my 4.9s with just a socket set and a cheap supercheap press. |
| Author: | andy1517 [ Wed Oct 27, 2010 10:36 pm ] |
Won;t be trying it by myself...I know my limits. Don't you need to shim? Rather pay someone to do it, and not have to worry when up in the bush...as much! |
| Author: | whincup [ Thu Oct 28, 2010 8:19 am ] |
not 100% since ive never done anything like this myself, but pretty sure u only need to shim when installing the 6.5's... 4.9's is fine AFAIK... |
| Author: | steak_knife [ Thu Oct 28, 2010 10:06 am ] |
Std's have shim's & if changing bearing's thay may need to be set again.. |
| Author: | Hybrid [ Thu Oct 28, 2010 9:58 pm ] |
andy1517 wrote: Won;t be trying it by myself...I know my limits. Don't you need to shim?
Rather pay someone to do it, and not have to worry when up in the bush...as much! No worries. I understand that logic all too well. Unfortunately I can turn off the worry part until I'm stuck in the bush. |
