http://auszookers.com/forum/
which transfer wt or nt?
http://auszookers.com/forum/viewtopic.php?f=5&t=16313
Author:  Ridge [ Fri Oct 29, 2010 4:26 am ]
Post subject:  which transfer wt or nt?
i need a transfer case to put my 6.5s into, i have access to a free one from a nt with the hand break on the rear output, or a cheap wt case.
can i pull off the hand break drum and fit a wt flange instead? I will have a hand break with my rear disc conversion.
Author:  tanshi [ Fri Oct 29, 2010 4:28 am ]
Post subject:  Re: which transfer wt or nt?
yes you can put a flange on, it needs to be the correct one from the rear i believe as they are different to the front and top flanges
Author:  Gwagensteve [ Fri Oct 29, 2010 4:36 am ]
Just remember that the NT and WT flange patterns are different, so if you swap the NT handbrake onto a WT case you'll also need a nt yoke for your rear driveshaft.
Author:  Ridge [ Fri Oct 29, 2010 6:11 am ]
great, i already have some wt flanges and shafts. ill get started on it this weekend.
