It is currently Tue Nov 17, 2026 7:45 pm
Post Posted: Thu Oct 28, 2010 6:02 am
I pulled up next to a similar Vit today and noticed I sat a decent about higher than he did even though I thought my suspension was stock.
What is the standard height and where do I measure it from?
Thx.
Post Posted: Thu Oct 28, 2010 6:12 am
I'm not sure about what the stock height is, but are you running larger tyres or anything else that may affect the height?
Also if he had, say a big heavy bullbar on the front and a big heavy toolbox in the back it would sit lower too....
Also, he may have shagged out old springs which are sagging to make it sit lower...
I want my old sig back :(
Vehicle: Vitara 90'
Post Posted: Thu Oct 28, 2010 6:25 am
Yeah mine feels tall too, I've got 30's so that's a 2 inch lift from the stock 26" wheels :D
Post Posted: Thu Oct 28, 2010 6:27 am
mine feels tall but maybes thats the lift but id say he just had sagged springs
Post Posted: Thu Oct 28, 2010 10:24 am
I took some measurements when I did my lift - these are for original sagged bits:
http://www.auszookers.com/index.php?nam ... sc&start=0
About half way down the page.
Post Posted: Thu Oct 28, 2010 11:56 am
Thanks, I'll measure and compare.
Post Posted: Fri Oct 29, 2010 1:21 am
Just took a couple of measurements to compare with yours Darkhorse.
Front drivers top of wheel arch to ground.
Darks: 765mm
Mine: 800mm
Front drivers top of wheel arch to hub.
Darks: 450mm
Mine: 450mm
Sill ground clearance.
Darks: 250mm
Mine: 300mm
Rear shocks look newish...pedders comfort gas I think I read ;)
Tyres are 235/75/15
Post Posted: Fri Oct 29, 2010 9:11 am
Mine were stock 205/70s, so that accounts for some of the difference. From memory the pedders stuff doesn't give much lift, but are much stiffer. Someone might be able to confirm/deny that.
Users browsing this forum: Google [Bot] and 67 guests
