| rotor button / trouble firing http://auszookers.com/forum/viewtopic.php?f=5&t=16471 |
| Author: | maloo11 [ Thu Nov 04, 2010 7:47 am ] |
| Post subject: | rotor button / trouble firing |
Rotor button is hitting the inside of the dizzy cap, of about 1.5in just befoe it strikes the lead for No2. Are there diffrent rotor buttons or do they wear out? Wats the solution, new rotor and cap? Ok, so put new rotor button and dizzy cap on, this solved the scraping of the inside. But it still isnt firing properly. Heres wat happens while the engine is runnin, and i pull the lead off that plug only. No1 Dies down a bit No2 Nothing!! No3 Stalls No4 Dies down a bit Wats happening with No2 and No3? |
| Author: | Brett [ Thu Nov 04, 2010 7:52 am ] |
| Post subject: | Re: rotor button |
does the shaft have lots of play in it? could be time for a new dizzy or have you just replaced the button? |
| Author: | maloo11 [ Thu Nov 04, 2010 8:05 am ] |
na, havent touched it. Is running rough so i checked plugs and leads was fine, only 12months old anyway. So took a look at dizzy cap and its got a gouge in it, so i figured thats a prob. |
| Author: | steak_knife [ Thu Nov 04, 2010 10:18 am ] |
Don't have to get a new one, you can get new seal's & bearing for em.. |
| Author: | maloo11 [ Fri Nov 05, 2010 5:02 am ] |
| Post subject: | Re: rotor button / trouble firing |
bump |
