It is currently Thu Oct 29, 2026 1:03 pm
Post Posted: Tue Nov 09, 2010 6:50 am
Hi all, I have a 99 jimny with the 13bb engine 190,000ks, I get this noise through the drive system when you release the clutch in neutral, it gets this ticking rough bearing noise, when you engage the clutch it goes qiet, im not familar with suzuki and wonder if theres any ideas, is there a spigot bearing or some thing that can be replaced while i do the clutch or is it common g/box issue
thanks
luke
Post Posted: Tue Nov 09, 2010 7:27 am
Could be g/box input shaft bearing could be G/box out of oil..
Post Posted: Tue Nov 09, 2010 7:48 am
oils good,
Post Posted: Tue Nov 09, 2010 7:51 am
How loud is it, just a noise or a rumble??
Post Posted: Tue Nov 09, 2010 8:20 am
tickity rumble, you have to listen for it.
but def a new noise
Post Posted: Wed Nov 10, 2010 4:58 am
Throw out bearing.
Post Posted: Wed Nov 10, 2010 6:47 am
squizzytaylor wrote:
Throw out bearing.
It would change pitch when the peddle was depressed..
hard to tell with out hearing it..
What part of bris you in??
Post Posted: Wed Nov 10, 2010 7:09 am
mine does the same, i thought it was the thrust bearing and when i got a new clutch the noise was gone, but it has started again but is much quieter now, i mentioned it to suzistore and they think its the gearbox and isnt a problem.
Post Posted: Wed Nov 10, 2010 7:18 am
yea its not the throw out bearing its when the clutch isnt enganged, well ive also got a spiggot bearing orders aswell, and will find out this wkend when i pull the g/box out to do the clutch
Post Posted: Sun Nov 14, 2010 4:27 am
found the noise, spiggot bearing siezed in back of flywheel, which has chewed the end of the input shaft out, so now gear box is apart and am gunna machine input shaft, any one know how much a g/box rebuild kit is worth
Users browsing this forum: No registered users and 363 guests
