| sierra door handles http://auszookers.com/forum/viewtopic.php?f=5&t=16683 |
| Author: | angus350 [ Thu Nov 11, 2010 9:46 am ] |
| Post subject: | sierra door handles |
is the outer door handles on sierra both different ? as in drivers and passengers. i have just had doors re sprayed and have re assembled the passenger side fine all works good, but , the drivers side one when bolted up hits the paint work for some reason when lifted up to open the door, also doesnt pull the lock, i hade 4 doors in total and have mixed up the handles ( why i dont know if they are different or not ) any help would be appreciated thanks benn |
| Author: | alien [ Thu Nov 11, 2010 11:57 am ] |
| Post subject: | Re: sierra door handles |
they are different. |
| Author: | want33s [ Thu Nov 11, 2010 8:23 pm ] |
The pushrod lever on the handle goes to the back edge of the door. So looking at a handle out of the car, if it has the lever on the left it is a right door handle and vica versa. |
| Author: | coily96 [ Fri Nov 12, 2010 7:34 am ] |
Left = left door right = right door and tail gate. |
| Author: | steak_knife [ Fri Nov 12, 2010 8:44 am ] |
coily96 wrote: Left = left door
right = right door and tail gate. Only for tin top's & high top's.. |
| Author: | angus350 [ Sat Nov 13, 2010 11:37 am ] |
ill have a check tomoro and see if i can sort it out , also can you buy new door rubber seals thingo's , one of mine is munted im sure you can buy new ones with new clips some where ? thanks |
| Author: | 96coily [ Sat Nov 13, 2010 12:58 pm ] |
angus350 wrote: ill have a check tomoro and see if i can sort it out , also can you buy new door rubber seals thingo's , one of mine is munted im sure you can buy new ones with new clips some where ?
thanks Where did you hear that term ..... Murrin? |
| Author: | want33s [ Sat Nov 13, 2010 7:22 pm ] |
Suzistore sell door rubbers. |
| Author: | angus350 [ Sun Nov 14, 2010 9:57 am ] |
96coily wrote: angus350 wrote: ill have a check tomoro and see if i can sort it out , also can you buy new door rubber seals thingo's , one of mine is munted im sure you can buy new ones with new clips some where ? thanks Where did you hear that term ..... Murrin? murrin ? munted , as in fucked, rooted, turned to shit , ect thanks want33s ill give them a ring this week |
