It is currently Thu Oct 29, 2026 1:02 pm
Post Posted: Thu Nov 11, 2010 11:11 pm
well the idea was to try and pull the motor and gearbox out in one, so today i went to figure out how to remove the gearstick, i removed the knob, the bottom plate with 3 bolts, the washer under that and found the bush under that had perished pretty bad and as i was pulling that out the stick come out, wasn't sure if it was meant to come out so easy?, anyway my problem now is that i went to put the stick back in to make sure it was as easy as that and try to select some gears, stick goes in fine, feels like its in neutral, but wont select any gears? have i done something wrong? broken something? i dont have a bush in there or the plate bolted down but still thought it should select gears
Post Posted: Thu Nov 11, 2010 11:13 pm
was it in neutral when you pulled it out? sounds like you are putting it in off to teh side of the gates, peer into the hole and youll see the slot it goes into, its not easy but it goes in
Post Posted: Thu Nov 11, 2010 11:21 pm
yeah was in neutral when i pulled it out, and i will have another go but deffinately feels like its going in correctly
Post Posted: Thu Nov 11, 2010 11:51 pm
Try Spinning the output shaft to the box wilst trying to select a gear
Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
Post Posted: Fri Nov 12, 2010 12:07 am
still wont go into gear..?
Post Posted: Fri Nov 12, 2010 12:19 am
Have you got the box off the motor
Vehicle: 03 Jimny
Post Posted: Fri Nov 12, 2010 12:20 am
look in the hole and there shaft on both sides of the shaft that the gear stick goes into. make sure the side shaft thingy is pulled right back as far as it can go, then try
Post Posted: Fri Nov 12, 2010 12:24 am
have a look at the pics in this thread, it will give you an idea of lining up the shift rails.
http://auszookers.com/index.php?name=Fo ... ifter+bolt
Post Posted: Fri Nov 12, 2010 1:15 am
cheers zooky and atari, got it, was actually in third :/ much appreciated guys
Post Posted: Fri Nov 12, 2010 1:21 am
you can undo the 4 bolts that hold the gear stick houseing in and (tap) it off with a hammer makes it easer to get the screw driver in to make the gates line up
Post Posted: Fri Nov 12, 2010 1:34 am
yeah thats actually what i ended up doing, should of i put like a gasket gue or something on it before i put it back on?
Post Posted: Fri Nov 12, 2010 12:11 pm
ummmm i didnt know maybe take it for a spin if it leaks take it back off and put some on but i think it should be right
Users browsing this forum: No registered users and 349 guests
