It is currently Mon Oct 26, 2026 10:55 pm
Post Posted: Sat Nov 13, 2010 3:05 am
Looking at doing half the work of installing an air conditioner (leaving the pipework and gassing to a professional) to keep costs down.
I've got a 1.6L G16A EFI in a SJ50 Tintop
Is a Compressor from a Sierra 1.3L Carby Compatible with the G16A EFI?
(ie: can i just get a sierra setup and it will work, or will I need a compressor from a vitara, the evaporator from a sierra, and the rest from either?)
1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
Post Posted: Sat Nov 13, 2010 3:11 am
I would think you would use everything from a sierra bar the compressor and bracketry that holds it to the engine.
you may need to get new houses made up for the ones that run to the compressor
I could be wrong though about the comoressor and a sierra one may fit.
Post Posted: Sat Nov 13, 2010 3:52 am
you can use all sierra stuff, the aircon bracket will need a little tab welded on
so that it fits the 1.6 block. there is photos in my build up thread where i put a 1.6 in my hardtop.
oh and the aircon clutch/pulley needs to be swapped for a multirib belt jobbie.
Post Posted: Sat Nov 13, 2010 6:07 am
thanks shep... just looking through the 26 pages now :P
this project might be put on hold for a little, just found a strip of rust holes below the windsheild... got a mate coming round with a welder tomorrow, might see if i can cut this out and get it done then, otherwise it'll be few weeks away at least.
Post Posted: Sat Nov 13, 2010 6:15 am
actually i had a look but i couldn't find it. i have a feeling that i might have
started a thread about the aircon issues.
might have to ask atari to find the thread.
Post Posted: Sat Nov 13, 2010 6:18 am
secondhand aircon bits suck, trust me I learnt the hard way
foonji is selling some bits you need, ive got a bracket to bolt a Sanden Compressor onto a 1.6 ill part with for a fee if you need one
Post Posted: Sat Nov 13, 2010 7:19 am
Paying near on $2000 for a brand newbie installed professionally sucks too...
I'm not too worried if it doesnt work overly that well, just something to take the edge off the wet season heat when its raining outside and i can't open the window... been up here for over 4 years now, and all 3 of the cars i've had in that time haven't had air con :S
I saw foonji's thread and thats why i started this one, but he's not willing to post *yet*
Everything except the compressor should be ok second hand hey? or you reckon I should get everything brand new?
Post Posted: Sat Nov 13, 2010 7:29 am
i can sell ya my setup. still gassed and sealed.
Post Posted: Sat Nov 13, 2010 7:42 am
including that bracket?
sounds like a deal, how much you want for it?
Post Posted: Sat Nov 13, 2010 7:47 am
it is still attached to a 1.6 which is attached to a WT swb hard top also comes with a LWB
roller and shitloads of other bits.
$800
Post Posted: Sat Nov 13, 2010 8:04 am
Ive spent more than that keeping a 'working system' running this year
my compressor died, old age and partly my fault for ignoring early signs of it, partly some other wankers fault for fitting the drier back to front when it was last serviced
So 'just replace the compressor' was my instruction to the AC guy, he did that and the drier (has to be done) and off I went, problem was the thing made a funny noise, take it back the the Evap and Condensor and TX valve have metal in them from the old compressor, fucked the TX and likely to move about and kill the compressor, so all replaced and more gas and its right as rain
Bit down the track I need to replace a hose (unrelated and I'm fucking pissed I didnt get it done at teh time the work was done) and its noisy again, send it back to teh dude and the bearings in the compressor are fucked, oil doesnt seem to be int eh compressor, so another compressor fitted and condensor and TX cause they have metal in them
Was announced as right as rain but its still noisy so it will have to get looked at again some time
If I just said do it properly the first time I would of had good AC and enough left over for an airlocker......
Users browsing this forum: No registered users and 519 guests
