It is currently Sun Nov 15, 2026 2:20 am
Post Posted: Sat Nov 13, 2010 8:08 pm
Sorting out the last of my headlight wiring and the dog's breakfast it was.
My last big issue is the numpty has pulled the cable compltly out of the loom plug under the dash (the one with a dozen odd wires in it) I cant for the life of my get the pin thats in there out, regardless of which way I poke it.
Have any of you more experienced guys got good tricks to getting it out so I can keep my loom as stock as possible?
Post Posted: Sat Nov 13, 2010 8:42 pm
The terminal have a small locking tang that holds them into the block.
You need to push the tang down and then the terminal will come out.
I have a dental tool modified for this job but a very small flat screwdriver will work.
Not the best pic but you can see the tang.
Post Posted: Sun Nov 14, 2010 2:29 am
thats what I thought. couldnt see it/snipe it loose for some reason.
Will give it another go later.
Post Posted: Tue Nov 16, 2010 6:16 am
still no love :( can't see said tang top or bottom of the pin so am just stabbing a little randomly with no luck.
have a small terminal driver the fits through the block so thats not the problem.
Post Posted: Tue Nov 16, 2010 6:22 am
Post a pic of the terminal block..
Post Posted: Tue Nov 16, 2010 6:23 am
Best photo's I could get sorry.
Is the plug that the wires for the headlights come down from the column in an 87 NT sierra.
The previous owner butchered them to put in relays and ran it back into the factory loom. :roll:
Post Posted: Wed Nov 17, 2010 7:26 am
photo's now added
Post Posted: Wed Nov 17, 2010 8:58 am
Just push the tang down and pull them out... The male side of the connector with the female spades in it has the tangs on the spades.
The female side of the connector with the male spades has the tangs built in to the plastic housing.
For these small ones I use a jewellery screwdriver.
Insert far enough to depress the tang and then turn 90 degrees. Pull on the wire and it comes out.
Wa lah!!!
Post Posted: Wed Nov 17, 2010 9:08 am
thanks, made it look easy!
will give it another go when I get a chance.
For the other side of the plug you do the same thing.
Insert the screwdriver far enough to raise the plastic tang.
Post Posted: Sat Nov 20, 2010 8:16 am
So I ground the end of a jewelers screwdriver down...
and I now have working headlights. armsup.
royce, ship this thread off to "good tech" ??
Users browsing this forum: No registered users and 45 guests
