http://auszookers.com/forum/
ga16ba conversion into seirra
http://auszookers.com/forum/viewtopic.php?f=5&t=16773
Author:  outram [ Sun Nov 14, 2010 11:07 pm ]
Post subject:  ga16ba conversion into seirra
hey guys just wonted to no how hard it is to put a ga16b motor into a seirra any advice welcome cheers
Author:  5ierra [ Sun Nov 14, 2010 11:09 pm ]
Post subject:  Re: ga16ba conversion into seirra
use the search function, there are 900 000 000 threads on this, we dont need another.
Author:  SuziBlu [ Sun Nov 14, 2010 11:14 pm ]
Help out or refrain from shit replies.
Author:  SuziBlu [ Sun Nov 14, 2010 11:21 pm ]
I suk at searching via the search button, so I had a look around, have a read of this besides being a ripper build, it also speaks of engines.
Author:  Ben_Sierra [ Sun Nov 14, 2010 11:24 pm ]
Just to confirm, by ga16ba, do you acctually mean g16a or g16b?
Cos there's a big difference between the two...
Author:  SuziBlu [ Sun Nov 14, 2010 11:30 pm ]
Ben, I have never done it, but arn't they the same in regards the nuts and bolt side, BeT kit, an reposition mounts, thats about it, then all the fancy stuff.
Author:  JrZook [ Sun Nov 14, 2010 11:30 pm ]
Not too hard at all. U'll need an adapter plate between the engine and gearbox (BenT off this forum makes a nice one). If its a G16 carby engine you will just have to modify the stock 1.3 carby hat to suit. If its the EFI version u'll need a high pressure fuel pump, some high pressure fuel hoses and a bit of wiring work.
Dan
Author:  atari4x4 [ Sun Nov 14, 2010 11:32 pm ]
zookernator did a write up in the tech articles but i can't get to it...
EDIT: found it http://auszookers.com/index.php?name=Fo ... hlight=vss
Author:  SuziBlu [ Sun Nov 14, 2010 11:45 pm ]
Crikey, I looked for that, how did u find it.
Me and search button hate each other.
Author:  atari4x4 [ Sun Nov 14, 2010 11:53 pm ]
Don't be a hater, teh search works well, i was sure it was in the tech articles but couldn't get to it or find it so i searched for "g16" & "threads" by "zookernator" knowing the author helps cut it right down to a couple of threads.
Author:  SuziBlu [ Mon Nov 15, 2010 12:00 am ]
lol knowing the words to use helps a lot, I didnt try the search, as it hates me, but I would have tried something like, g16 into sierra or 1.3 to 1.6 engine swap, whatever, and gotten no results.
Author:  Ben_Sierra [ Mon Nov 15, 2010 12:03 am ]
Its all the fancy stuff thats different...
To go EFI you gotta do all the wiring, fuel system etc etc. A lot more work than bolting a carby motor in ;)
Author:  atari4x4 [ Mon Nov 15, 2010 12:04 am ]
Sometimes more is less, especially if you know that thread exists. really this dribble should be in the Grimbo & the search function thread.
Sorry outram for taking this slightly off topic, have a read thru Zookernators write up & let us know if you need more info. Are you wanting to go EFI or stick with the carby 1.6?
Author:  BlueSuzy [ Mon Nov 15, 2010 12:13 am ]
Another G16B option http://www.auszookers.com/index.php?nam ... 23&start=0
Author:  steak_knife [ Mon Nov 15, 2010 9:16 am ]
Kind of on this note, does anyone know if the vit flying wheel is solid steel or cast??
Author:  zooky08 [ Mon Nov 15, 2010 10:22 am ]
steel im pretty sure steaky
Author:  BenT [ Tue Nov 16, 2010 7:51 am ]
The ones I have seen are a machined casting, same as the Sierra, and will probably be cast iron, not cast steel.
Ben
Author:  steak_knife [ Tue Nov 16, 2010 7:59 am ]
Ben
Cheer's.. So lightening's not an option..May have to get one made..
Author:  BenT [ Tue Nov 16, 2010 8:11 am ]
Your not going all ricer on us are you Stekky? Why you want lighter? Usually heavier makes for nicer offroading.
Ben
Author:  steak_knife [ Tue Nov 16, 2010 8:28 am ]
Ben
8O F*#k NO!!!!! 8O
Just a theory, I'm getting a vit box to go into Sully & don't want to loose the quick rev's of having the sierra flying wheel on the 1.6 but want the bigger clutch.. :P
Author:  Damo [ Tue Nov 16, 2010 8:36 am ]
steak_knife wrote:
Ben
8O F*#k NO!!!!! 8O
Do us a favour and weigh the Vit flywheel and the Sierra flywheel. I bet the Vit one is a fackload heavier.
BTW, why can't you machine a cast iron flywheel?
Author:  steak_knife [ Tue Nov 16, 2010 8:46 am ]
You can, but if you lighten em to much that explode..just a lil bit. 8O
