It is currently Sat Sep 26, 2026 1:08 am
Post Posted: Mon Nov 15, 2010 7:29 am
I can't get 1st when the car warms up. Runs fine till warmed up. It is a 4spd auto, does anyone have any ideas what the problem could be?
Post Posted: Mon Nov 15, 2010 7:56 am
Mines a 4sp Auto.
It won't get first unless I pull stick back.
It may be by design, because don't need first much on road?
Post Posted: Mon Nov 15, 2010 9:26 am
Same with my 1994 till i did a full service on it.filter and Oil + a full flush.
Steve W
Post Posted: Mon Nov 15, 2010 11:11 pm
I'd say oil ATF is low and needs a service it should select first
Post Posted: Mon Nov 15, 2010 11:22 pm
When was the last time the auto was serviced?
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Tue Nov 16, 2010 12:27 am
Oil is good doesn't smell, serviced not too long ago. The OD off light flashes on the dash when warm also.
Post Posted: Tue Nov 16, 2010 5:52 am
That mean's it's found a fault..
Post Posted: Tue Nov 16, 2010 12:31 pm
go to suzi Auto at springwood if u cant fix it. right next door to the also is a gearbox service/ repair shop called highway auto's i think.
what oil did u use and did u service it yourself? penrite is great.
Post Posted: Tue Nov 16, 2010 6:44 pm
I will be going to auto electrician today to see what the fault code is.
Post Posted: Thu Nov 18, 2010 7:00 pm
Went to auto electrician, no faults were present, I am going to change the temp sensor see if that works.
Post Posted: Thu Nov 18, 2010 7:55 pm
What temp sensor are you talking about.
Steve W
Post Posted: Thu Nov 18, 2010 8:59 pm
coolant temp. the auto needs it.
Post Posted: Thu Nov 18, 2010 10:22 pm
There are 3 of them (94 LWB) 1 in the front and 2 in the side of the Thermostat housing.
One thing to watch out for on the front one ( Temp gague ) is make sure you get a long one about 45mm or it will not reach the water in the housing and gives a faulse reading, also the one in the side ( Lower) needs to be the same length.
Lift the thermostat out and check.
Steve W
Post Posted: Mon Nov 22, 2010 7:07 am
I replaced the coolant temp sensor, wasn't that, as there was no fault code showing I am thinking maybe the problem is a solenoid in the gearbox, anyone able to help or me or have idea of what the problem could be?
Post Posted: Mon Nov 22, 2010 7:17 am
I dont think the solonoid would cause it to not select first when it was warm and be fine when cold(I am no expert). It sounds more like the fluid level or there is a block in the system. Was the filter changed when it was serviced.
Users browsing this forum: Google [Bot] and 100 guests
