| Author |
Message |
outram
Joined: Mon Aug 30, 2010 9:51 am Posts: 130 Location: newcastle
Vehicle: suzuki sierra sj80
 Posted: Sun Nov 14, 2010 11:07 pm |
hey guys just wonted to no how hard it is to put a ga16b motor into a seirra any advice welcome cheers
5ierra
Joined: Tue Mar 09, 2010 10:30 pm Posts: 1645 Location: Ipswich
 Posted: Sun Nov 14, 2010 11:09 pm |
use the search function, there are 900 000 000 threads on this, we dont need another.
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Sun Nov 14, 2010 11:14 pm |
5ierra wrote: use the search function, there are 900 000 000 threads on this, we dont need another.
Help out or refrain from shit replies.
_________________ Bad decisions make good stories.
SuziBlu
 Posted: Sun Nov 14, 2010 11:21 pm |
I suk at searching via the search button, so I had a look around, have a read of this besides being a ripper build, it also speaks of engines.
Ben_Sierra
Joined: Wed Sep 30, 2009 11:30 pm Posts: 4472 Location: Perth
 Posted: Sun Nov 14, 2010 11:24 pm |
Just to confirm, by ga16ba, do you acctually mean g16a or g16b?
Cos there's a big difference between the two...
_________________ I want my old sig back
SuziBlu
 Posted: Sun Nov 14, 2010 11:30 pm |
Ben, I have never done it, but arn't they the same in regards the nuts and bolt side, BeT kit, an reposition mounts, thats about it, then all the fancy stuff.
JrZook
outram wrote: hey guys just wonted to no how hard it is to put a ga16b motor into a seirra any advice welcome cheers
Not too hard at all. U'll need an adapter plate between the engine and gearbox (BenT off this forum makes a nice one). If its a G16 carby engine you will just have to modify the stock 1.3 carby hat to suit. If its the EFI version u'll need a high pressure fuel pump, some high pressure fuel hoses and a bit of wiring work.
Dan
_________________ Lil Foot!
atari4x4
 Posted: Sun Nov 14, 2010 11:32 pm |
SuziBlu
 Posted: Sun Nov 14, 2010 11:45 pm |
Crikey, I looked for that, how did u find it.
Me and search button hate each other.
atari4x4
 Posted: Sun Nov 14, 2010 11:53 pm |
SuziBlu wrote: Crikey, I looked for that, how did u find it.
Don't be a hater, teh search works well, i was sure it was in the tech articles but couldn't get to it or find it so i searched for "g16" & "threads" by "zookernator" knowing the author helps cut it right down to a couple of threads.
SuziBlu
 Posted: Mon Nov 15, 2010 12:00 am |
lol knowing the words to use helps a lot, I didnt try the search, as it hates me, but I would have tried something like, g16 into sierra or 1.3 to 1.6 engine swap, whatever, and gotten no results.
Ben_Sierra
 Posted: Mon Nov 15, 2010 12:03 am |
SuziBlu wrote: Ben, I have never done it, but arn't they the same in regards the nuts and bolt side, BeT kit, an reposition mounts, thats about it, then all the fancy stuff.
Its all the fancy stuff thats different...
To go EFI you gotta do all the wiring, fuel system etc etc. A lot more work than bolting a carby motor in
atari4x4
 Posted: Mon Nov 15, 2010 12:04 am |
Sometimes more is less, especially if you know that thread exists. really this dribble should be in the Grimbo & the search function thread.
Sorry outram for taking this slightly off topic, have a read thru Zookernators write up & let us know if you need more info. Are you wanting to go EFI or stick with the carby 1.6?
BlueSuzy
 Posted: Mon Nov 15, 2010 12:13 am |
steak_knife
 Posted: Mon Nov 15, 2010 9:16 am |
Kind of on this note, does anyone know if the vit flying wheel is solid steel or cast??
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Mon Nov 15, 2010 10:22 am |
steel im pretty sure steaky
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
BenT
Joined: Sun Nov 16, 2008 10:30 pm Posts: 208 Location: Nelson, NZ
Vehicle: 85 SJ413
 Posted: Tue Nov 16, 2010 7:51 am |
steak_knife wrote: Kind of on this note, does anyone know if the vit flying wheel is solid steel or cast??
The ones I have seen are a machined casting, same as the Sierra, and will probably be cast iron, not cast steel.
Ben
_________________ WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
steak_knife
 Posted: Tue Nov 16, 2010 7:59 am |
BenT wrote: steak_knife wrote: Kind of on this note, does anyone know if the vit flying wheel is solid steel or cast?? The ones I have seen are a machined casting, same as the Sierra, and will probably be cast iron, not cast steel. Ben
Cheer's.. So lightening's not an option..May have to get one made..
BenT
Vehicle: 85 SJ413
 Posted: Tue Nov 16, 2010 8:11 am |
Your not going all ricer on us are you Stekky? Why you want lighter? Usually heavier makes for nicer offroading.
Ben
steak_knife
 Posted: Tue Nov 16, 2010 8:28 am |
BenT wrote: Your not going all ricer on us are you Stekky? Why you want lighter? Usually heavier makes for nicer offroading.
Ben
 F*#k NO!!!!!
Just a theory, I'm getting a vit box to go into Sully & don't want to loose the quick rev's of having the sierra flying wheel on the 1.6 but want the bigger clutch..
Damo
Joined: Sat Jul 22, 2006 11:30 pm Posts: 4661 Location: Brisbane
 Posted: Tue Nov 16, 2010 8:36 am |
steak_knife wrote: BenT wrote: Your not going all ricer on us are you Stekky? Why you want lighter? Usually heavier makes for nicer offroading.
Ben  F*#k NO!!!!! Just a theory, I'm getting a vit box to go into Sully & don't want to loose the quick rev's of having the sierra flying wheel on the 1.6 but want the bigger clutch..
Do us a favour and weigh the Vit flywheel and the Sierra flywheel. I bet the Vit one is a fackload heavier.
BTW, why can't you machine a cast iron flywheel?
_________________ SJ50.4.LYF
steak_knife
 Posted: Tue Nov 16, 2010 8:46 am |
Damo wrote: Do us a favour and weigh the Vit flywheel and the Sierra flywheel. I bet the Vit one is a fackload heavier.
You can, but if you lighten em to much that explode..just a lil bit.
