It is currently Mon Oct 05, 2026 1:41 pm
Vehicle: LPG 1.6 Sierra
Post Posted: Tue Nov 16, 2010 10:13 am
I bought a 12v socket --> USB adaptor from jaycar yesterday to power up the iPod in the car. I have the ipod connected to the car stereo via an aux in. But, if I have the iPod running and recharging at the same time I get some wierd computery electro interference through the speakers. Pull out the power and music playback is peachy again.
Is this a grounding issue?
Post Posted: Tue Nov 16, 2010 11:09 am
It's the transformer in the USB making ellectrical noise, kinda the same as an old tv if you ran a 240v power drill near it,, it went ape shit, not alot you can do about it, mine old one done the same thing, then I just bought a proper fusion iPod intergrated head deck, problem solved,
Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
Vehicle: 93 Sierra
Post Posted: Tue Nov 16, 2010 11:28 am
100% normal. You can fit a line noise filter to the radio (Jaycar stock them) which will help but you'll likely still have a high pitched whine. I just avoid charging the iPod while I'm using it.
Post Posted: Tue Nov 16, 2010 11:46 am
Something that might work would be setting the audio ground the the vehicle ground.
I have this same problem, havnt tried to fix it though, just avoid charging and listening.
Go hard,
Post Posted: Tue Nov 16, 2010 7:15 pm
see if you get a buzz using headphones while charging from your usb doohicky
Post Posted: Tue Nov 16, 2010 11:00 pm
I just tried this - no noticeable noise in headphones, but right there when you plug back into the aux in.
Post Posted: Tue Nov 16, 2010 11:09 pm
its an earth loop then, hum created by 2 different signal earth points, try earthing the usb and radio to the same point (in theory works, in practice it doesnt)
Or try a ground loop isolator, though by the time you stuff around getting one and converting the RCA ends to 3.5mm youve spent a lot of money
Users browsing this forum: No registered users and 220 guests
