It is currently Fri Oct 02, 2026 10:15 pm
Vehicle: 03 Jimny
Post Posted: Wed Nov 17, 2010 6:55 am
After my car blowing alot of smoke and running like a bucket of shit. I got the chance to take the head off. Theres alot of black shit or carbon over the pistons and the spark plugs and valves are covered in it. It was blowing alot of blue smoke, so thats some thing to do with oil. How do i no if my oil rings are stuffed or not. I pressure tested the compression and i got 150 on all four(4) pistons, so the compression rings are good i think. What is coursing my car to blow alot off smoke.
How much play should the pistons have in the bore coz they do move around abit in ther. Btw smoke is only coming from piston three(3) at this stage
If i replace the rings and get new valves an reseat them would that fix the smoke or should i just clean the piston nd valves nd get them reseated. Im thinking itll be better if i just replace every thing while i have the head off.
Post Posted: Wed Nov 17, 2010 8:19 am
I would also check and if needed replace the valve stem seals. I have checked a couple of "knackered" engines showing good numbers on compression but with leaking valve stem seals. Replace and life is good. May not be in your case but worth a look.
Even if you have well seated rings but the oil ring has failed you will get smoke.
Before we go too far into it, how do you know is no. 3 is smoking? Plug fouled?
Vehicle: 03 Jimny
Post Posted: Wed Nov 17, 2010 8:32 am
All the spark plugs are black. But three is worse. Took the exhaust manifold off and started car up. Only smoke coming from cylinder three and abit of oil coming out. So im guessing some thing in cylinder three has gone
Post Posted: Wed Nov 17, 2010 10:37 am
How many k's on the engine? Being only one cylinder playing up I would say stem seals.
With the head off how did no. 3 look on the cylinder wall?
Vehicle: 03 Jimny
Post Posted: Wed Nov 17, 2010 11:02 am
Has 216 *** on it but has g16a in my car nd not sure how many k's the engine has done but looks like it has been rebuilt not long ago (maby a year) as it has gasket glue all in the joins.
The cylinder sleeve looked like all other cylinder. There all fine
Vehicle: 03 Jimny
Post Posted: Thu Nov 18, 2010 6:46 am
valves
pistons
Post Posted: Thu Nov 18, 2010 6:52 am
Bore's are shiny, could do with a hone, but you have it apart so rebuild :P
Pull one of the no3 valve's out & see if the oil's running down that..or just roll the cam enough to open em & take a pic..
Vehicle: 03 Jimny
Post Posted: Thu Nov 18, 2010 8:57 am
Ill upload a pic tommorow
Post Posted: Thu Nov 18, 2010 9:02 am
Is that coolant I see inside the cylinder head there on number 1? Hasn't done a head gasket or something has it? The smoke could actually be steam...
Also, it looks like a longer plug on number 3 than the others?
I want my old sig back :(
Vehicle: 03 Jimny
Post Posted: Fri Nov 19, 2010 2:06 am
That is coolant but i have put it there myself. Spark plugs are all the same. Just no. 3 could be tightened more then the other.
The car only blows smoke under acceleration or load. Not sure if thats any help
Post Posted: Fri Nov 19, 2010 2:35 am
Well whiles is apart get it honed and go oversize slugs and rings. Strip the head down and also check for excessive play in the valve guides. If so get new ones pressed in also.
Dan
Lil Foot!
http://tiny.cc/gtsw1
Users browsing this forum: Google [Bot] and 176 guests
