It is currently Sun Oct 04, 2026 5:21 am
Post Posted: Wed Nov 17, 2010 5:02 pm
I would like to fit power steering to my '89 widie just wondering how difficult and complicated the job would be and also if there are any conversions available???
Post Posted: Wed Nov 17, 2010 5:51 pm
Look in the buisness section for BenT conversion kits. His P/S kit makes a vitara setup an easy bolt in conversion. Jimny PS will fit also, no conversion kit needed but the setup is 2-3 times more expensive to but then vitara.
When doing your conversion it is a good idea to put in new oil lines. I got a single high pressure line made up for around $100, makes it easier to fit also as the vitara lines are steel and don't fit the chassis rails of the Sierra alll that well.
Post Posted: Wed Nov 17, 2010 6:34 pm
cressida is 100% custom work, but a smaller, stronger box then the vitara, it also is more powerful...
Post Posted: Wed Nov 17, 2010 7:46 pm
Jimny is bolt in...
Post Posted: Wed Nov 17, 2010 9:18 pm
steak_knife wrote:
Jimny is bolt in...
:wink:
Post Posted: Wed Nov 17, 2010 9:28 pm
Bruce wrote:
steak_knife wrote:
Jimny is bolt in...
:wink:
:wink:
Vehicle: SJ80
Post Posted: Wed Nov 17, 2010 10:45 pm
What year / model range do the cressida power steering boxes need to come from?
What is the over view of the work required for the cressida steering box install?
Drill some holes in the chassis rail?
Make a braket from some plate?
Get new pipes made?
What is require for the drag link, Pitman arm to come together? etc...
Post Posted: Thu Nov 18, 2010 12:17 am
dose any one have pics of the benT kit installed ??? or any one used it
Post Posted: Thu Nov 18, 2010 1:55 am
I've used it, it even fits a coily :P Probably took an hour or so to install
Users browsing this forum: No registered users and 201 guests
