http://auszookers.com/forum/
rear bearings
http://auszookers.com/forum/viewtopic.php?f=5&t=16874
Author:  sbbunno [ Thu Nov 18, 2010 1:47 am ]
Post subject:  rear bearings
ok so i followed the manual to the letter butbut the axel shaft wont budge from the housing everything is disconected. :evil:
is there any sorta trick i need to know
im workig on it just now so would appreciat some help
thannks in advance
scott
Author:  royce [ Thu Nov 18, 2010 1:50 am ]
Post subject:  Re: rear bearings
make sure the car is securely on stands
slip the drum back on backwards and chuck a few nuts on a few turns
use drum like a slide hammer to work it out
if that fails, drum on properly and stick the wheel in withthe nuts on a few turns, try not to pull the car on top of you
Author:  sbbunno [ Thu Nov 18, 2010 1:52 am ]
the axel is out on stands jus know but ill give that i try and get back to ya
Author:  royce [ Thu Nov 18, 2010 1:57 am ]
you need to hold the housing down with something then, tie it to a tree :)
Author:  sbbunno [ Thu Nov 18, 2010 2:14 am ]
haha got my girlfriend to hold it
ok one out gotta get the other now and take it to a dealer to get the besrings off and new ones on
Author:  sbbunno [ Thu Nov 18, 2010 8:58 am ]
all off and finished cheers
