It is currently Sat Nov 14, 2026 12:06 pm
Post Posted: Sat Nov 20, 2010 6:42 am
hi all just a quick question,went out for a wheel with deadzook this morning,went sweet and drove some cool shit then get home n notice oil over drivers rear wheel
so just now i have jacked it up,popped out seal inside the axle tube as i have had new ones for years to go in(dont have the outer casing tho but are the right size 62x48x8) :? but my wheel bearing is buggered,bad.can grab it and wiggle it about 5mm side to side but it hasnt been noisy in anyway or felt different
So....if i can get a bearing in the morning is it easy enough to get bearing and little ring off the axle or should i get it to a shop?how have you done it without a press. also guess ill drop the other side and do seal also and see how it is? thanks
Post Posted: Sat Nov 20, 2010 6:44 am
Have a search for a really good thread here somewhere, even had pretty pictures. Just requires a grinder and a long tube.
Post Posted: Sat Nov 20, 2010 6:50 am
Here is Sheps dodgy work
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Sat Nov 20, 2010 6:54 am
Post Posted: Sat Nov 20, 2010 6:58 am
ah tru thankyou for that,i didnt find that
so basically a kit comes with the bearing and retainer??i dont have a press here yet and dont like the idea or grinding haha.
Post Posted: Sat Nov 20, 2010 7:02 am
and will the seal i have without the outer casing like stock one i pulled out still be up to the job???
You won't get it apart in a press, I've tried :wink: Grinder is not as dodgy as it sounds
Post Posted: Sat Nov 20, 2010 7:05 am
ok then cheers for that mate.will cut the bearing and retainer off tomorrow.So in sheps thread where they say not to heat retainer to get it on,do they go on easy enough as is?
Post Posted: Sat Nov 20, 2010 7:23 am
seems i may of just got a lend of a axle for now until i fix this one but i will order two sets and do other side while im at it.
so scrawn,do you hit the retainer on without anyheat and just some 32 heavy?
Post Posted: Sat Nov 20, 2010 7:35 am
No need to heat, just hit, but before you start bashing it on, be sure the bearing is on the right way, then the retainer goes on the same way, just hit.. :P
Post Posted: Sat Nov 20, 2010 7:41 am
Bit of pipe and a big hammer or just heavy pipe will do it. Press at work if ya get stuck.
Post Posted: Sat Nov 20, 2010 11:42 am
yeah cheers man,we have a half assed attepmt of a press at ours so if i get stuck might get ya to throw it on and ill fix ya up but im sure ill get it at home with a hammer haha
got it all back together a few hours ago with a borowed axle off deadzook,thanks joe 8) just had to pinch my brakes for now but will get my new bearings and brakeshoes ive had here for a bit fitted up asap
have never had to do a rear bearing before so will be good to learn a bit more,cheers for the links etc
Post Posted: Sun Nov 21, 2010 4:49 am
got some bearings today,was gonna get em off weaves but they were on the shelf here so thought why not
only thing i see is that the retainer is 48x35x16 not x20 like the ones on it at the moment. is this going to be a problem where the seal runs or should i be right??
they are network bearing kit rear 1958 on the box.But one box has NM.MT other has MT.NZ dunno if they mean anything but both kits are all the same size.
Post Posted: Sun Nov 21, 2010 6:19 am
the retainer width won't make a difference, so long as the seals seats on it centrally, and not over the edge, it will be fine
Users browsing this forum: No registered users and 82 guests
