| sierra funny noise on cold starts http://auszookers.com/forum/viewtopic.php?f=5&t=16919 |
| Author: | the_WIZARD [ Sat Nov 20, 2010 9:48 am ] |
| Post subject: | sierra funny noise on cold starts |
hey guys when i start my 1993 sierra on a cold start i get this grinding sorta noise only lasts a touch longer than the starter spinning, and doesnt happen when its a warm start.... any ideas?? |
| Author: | ellis [ Sat Nov 20, 2010 10:27 am ] |
| Post subject: | Re: sierra funny noise on cold starts |
idk mine does the same but |
| Author: | the_WIZARD [ Sat Nov 20, 2010 11:08 am ] |
cool so we both have a prob... can anyone help?? cuz 2 zooks out there are sick!! we cant have the big boys ruling the roads.... strength in numbers!! |
| Author: | steak_knife [ Sat Nov 20, 2010 1:18 pm ] |
Starter drive, the bit that contact's the flywheel, has a clutch in it for once the eng running.. you could strip, clean & re assemble, but will do the same in no time.. |
| Author: | hooki [ Sat Nov 20, 2010 4:30 pm ] |
could be time for a new starter. I pulled my starter out and cleaned it many times as it wouldnt disingage properly, the fix would only last a month or so and would get worse each time. I cbf pulling it apart anymore so i bought a new one. |
| Author: | 31zook [ Sat Nov 20, 2010 4:30 pm ] |
steak_knife wrote: Starter drive, the bit that contact's the flywheel, has a clutch in it for once the eng running..
you could strip, clean & re assemble, but will do the same in no time.. i once saw a guy put a barb air fitting on his, and air pressure from a tank get slammed through it after a mud run or has positive pressure running through it while in the mud..... i thought it was a smart idea |
| Author: | jonno_racing [ Sat Nov 20, 2010 9:46 pm ] |
31zook wrote: steak_knife wrote: Starter drive, the bit that contact's the flywheel, has a clutch in it for once the eng running.. you could strip, clean & re assemble, but will do the same in no time.. i once saw a guy put a barb air fitting on his, and air pressure from a tank get slammed through it after a mud run or has positive pressure running through it while in the mud..... i thought it was a smart idea mate had that in his disco, also had it running to, dizzy, diffs, gbox, transfer and winch gearbox. |
