I was in the same boat and ended up putting a push button start on temporarily. It's really quite easy after unplugging the wire to the ignition barrel.
Can't help you with sourcing a new key and barrel as my "temporary" fix has yet to be removed.
i removed the drivers side door barrel it has a code engraved on it they can use the code and get it exact for your car if you use a barrel without the code they will not guarantee the key to work its like 25$ to get it done and take like 5 mins
Users browsing this forum: No registered users and 72 guests
