It is currently Thu Oct 08, 2026 9:33 am
Vehicle: G16b 83
Post Posted: Sun Oct 10, 2010 12:14 am
what is evryones zook (sierra) idleing at
Post Posted: Sun Oct 10, 2010 12:39 am
I think a norm idle is about 750 when warming up about 1000 ?
My Maruti build, Click WWW
Post Posted: Sun Oct 10, 2010 12:52 am
mine idles at 1200 when warm think its a bit high would like around 1000
93 sierra 2"spring2"body 31,s & 4.9s
Post Posted: Sun Oct 10, 2010 12:58 am
I set mine at a grand.
Post Posted: Sun Oct 10, 2010 1:19 am
X2
Vehicle: G16b 83
Post Posted: Sun Oct 10, 2010 1:38 am
cheers what about timing at idle
Post Posted: Sun Oct 10, 2010 2:09 am
Post Posted: Sun Oct 10, 2010 3:10 am
Post Posted: Sun Oct 10, 2010 3:16 am
Vehicle: I drive your mum
Post Posted: Sun Oct 10, 2010 9:44 am
Timing is set at 11deg BTDC. Idle is round a grand, but i am re-tuning at the moment so i will see how it all turns out.
Layto....
Vehicle: G16b 83
Post Posted: Thu Nov 25, 2010 5:51 am
do you have to take your vacume advance off the dizzy before checking the timing
Post Posted: Fri Nov 26, 2010 4:56 am
i use your thread as i have idle speed related question too.
i got my carby fixed by carby specialist and they set up idle speed VERY LOW and said that it's ok like that. it's around 500RPM, just below the first mark on tacho. i don't mind that, but steak_knife had a good point saying that with so lo idle there might be not enough oil pressure and cam and crankshaft might not be oiled properly. what do you think guys?
cheers
kris
Post Posted: Fri Nov 26, 2010 8:36 am
Suzuki set the idle at 850rpm (+/-50) for a reason. I would leave it there.
Layto....
Post Posted: Fri Nov 26, 2010 9:20 am
Layto....
what about choke idle speed, when cold it idles not faster than when warm, same 500RPM or less. is it somewhere underneath choke? i have vit carby
Users browsing this forum: Google [Bot] and 166 guests
