It is currently Mon Oct 19, 2026 9:36 am
Post Posted: Sat Nov 27, 2010 6:50 am
G'day
I know that tacho in sierra is driven from dizzy. Is it possible that someone's done something wrong when putting g16a in my sierra so now tacho reads less RPM than it should. Is it possible that tacho by itself can show less? like a blown resistor or something. i have no idea about that topic, but it seams to me that the tacho reads less rpm than there is in reality. someone else drove my car today and he said same thing. any ideas?
cheers
kris
Post Posted: Sat Nov 27, 2010 6:55 am
totally possible, coniciding with an engine swap is pretty unlikely though
do you show less revs at a given speed than before?
Post Posted: Sat Nov 27, 2010 6:56 am
Is it EFi or carby? Sounds like the wrong wire has been tapped into
Post Posted: Sat Nov 27, 2010 10:01 pm
i put a g16a in mine the other day and now my rev counter does not work a all but was fine before the swap ????
Post Posted: Sun Nov 28, 2010 5:39 am
i bought my 91' sierra with g16a carby motor already in, also vitara manual gearbox, standard 3.7 difs, i added only 4.9 t-case gears, 31' (now closer to 30') the difference in gear ratio in sierra and vitara gearbox if any is rather unnoticeable. however at 100km'h in 5th gears tacho shows around 2800RPM which seams unlikely. engine doesn't seam to rev high, however below 3k at 100km is a bit unlikely. usually when driving revs range is between 1500-3000RPM, rarely 3500. that's why i think tacho might be out. if that's the case what should i check?
cheers
Post Posted: Sun Nov 28, 2010 6:22 am
yeah sounds like the tacho, I guess you need to get a diagram and make sure its hooked up properly, but its likely its stuffed
Post Posted: Sun Nov 28, 2010 7:05 am
Check your speed against a GPS, don't rely upon the speedo only, both my suzis are way out.
Post Posted: Sun Nov 28, 2010 8:39 am
i checked speed with gps. will i find that diagram in sierra service manual or i need special digram just for the tacho?
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 291 guests
