It is currently Mon Oct 12, 2026 2:47 pm
Post Posted: Mon Nov 29, 2010 9:15 am
Im fitting LED indicators/parker lights to the GV (in addition to the stock ones) - the rectangular ones in the link below
http://brytec.com.au/files/120%20&%20150%20Series.pdf
These LEDs are a sealed unit, with 3 wires - one for indicator, one for parkers, and one for ground. I've connected all 3 wires to the 3 wires on the back of the headlight - in effect, all paralell.
The LED indicator works fine, (with park lights off) as long as all 3 wires are just connected. If just the indicator and ground wires are connected nothing happens.
Also...
LED Parker light will not work. Stock one will.
LED Indicators will not work when park lights switched on. They'll work again when park light switched off.
At some point the stock park light bulb will blow. Happened twice now.
I've also tried connecting the LED wires directly to the battery - nothing happens - so im assuming theres some kind of circuit inside the sealed unit.
Now - i know from when wiring up the spotties to the highbeam that the GV has negatively switched circuits. This doesn't seem to be the case with the parker light, as i've checked it with a multimeter - it has 12v when swtiched on, and 0v when switched off.
Summary
- LED indicator works fine (until i switch the park light on).
- LED park light doesn't work at all, and keeps blowing the stock bulb.
- unit connected in paralell to stock wiring
Question - Anyone know what i should do??
My Grand Vitara
Post Posted: Mon Nov 29, 2010 9:26 am
Kinda sound's like a bad earth, do a continuity check with your multi at earth wire & body..
Post Posted: Mon Nov 29, 2010 9:28 am
switch the earth and the park light wires around
Post Posted: Mon Nov 29, 2010 9:33 am
Did that - connection is all good
My Grand Vitara
Post Posted: Mon Nov 29, 2010 9:35 am
Didn't think of that....but being LED's i don't think they'll work with polarity reversed.....could be wrong though....all the bloody wiring in the GV is backwards! :roll: :lol:
My Grand Vitara
Post Posted: Mon Nov 29, 2010 9:59 am
yeh.. kind of sounds like it is earthing out through the park light globe.. and would explain why the park lights arent working.
Post Posted: Mon Nov 29, 2010 10:05 am
I got curious so i just went out and tried it - nothing, not even the indicator works.
Tomorrow i'll try connecting the ground wire directly to the battery, this will determine if it is actually an earthing problem - once i buy a box of new parker globes! :lol:
My Grand Vitara
Post Posted: Mon Nov 29, 2010 10:07 am
pull the damn things out and try em with just a battery, confirm you get indicator, then parker without moving the earth wire then both together
Do you have a Brown, white and yellow or green wire on the light?
Post Posted: Mon Nov 29, 2010 10:12 am
Tried that already. Nothing works at all connected directly to the battery - hence why im thinking it has some inbuild circuit
wires are yellow (indicator), white (parker), and black (ground)
My Grand Vitara
Post Posted: Mon Nov 29, 2010 10:17 am
try the white as earth
Post Posted: Mon Nov 29, 2010 10:19 am
Thats what tintop suggested - now nothing works - see post above
My Grand Vitara
Post Posted: Mon Nov 29, 2010 10:24 am
direct to teh battery
in 125% of LED lights ive seen they share trailer wiring colour codes, which is usually white earth, yellow or green indicator and brown for parker
you know the yellow is indicator something, hook that to battery positive and one at a time hook the other wires to negative, one will light up the indicator, in theory the other is parker positve
if nothing lights up then try yellow on the negative and repeat the one at a time hook up to positive on the other 2, sooner or later youll get a combo that works or a wire that does nothing and somethings faulty
dont even bother trying to wire it to teh stock light wiring yet till you are sure they work and whats what
Post Posted: Mon Nov 29, 2010 10:30 am
Yeah i'll have to give that a shot tomorrow during daylight :roll:
My Grand Vitara
Post Posted: Mon Nov 29, 2010 6:24 pm
thats your problem, try doing it at night so you can see if they are lighting up....
Post Posted: Mon Nov 29, 2010 6:30 pm
pretty much all 12v stuff use white as the earth apparantley im told that is the 'international' colour for earth. we ahve lights on our vans that have a white and a black wire and the white is earth.
and not all leds are polarity sensitive but pretty much all are.
Post Posted: Mon Nov 29, 2010 10:25 pm
All LED's are polarity sensitive, because they are diodes.
Light Emiting Diodes in fact (LED).
IF you can't manage to get the LED's to work straight off the battery you will never get them working from the standard loom.
There is a finite number of wire combinations (6) and with LED's only one way will work.
I drive my Daihatsu like its a Suzuki!
Post Posted: Tue Nov 30, 2010 6:23 am
how did you go mate? get em to work??
Post Posted: Tue Nov 30, 2010 7:40 am
I've now tested the LEDs direct to the battery - and who would have thought, white is negative!! So much for assuming black is negative....
quickly hooked it up to the headlight too - didn't work though, im guessing coz the parker is blown at the moment. Should get time later this week to pull the head light assy out again to replace the bulb, then we'll try again.
My Grand Vitara
Post Posted: Tue Nov 30, 2010 7:44 am
get a freakin test light and work out where power is before you hook em up!!!!!
Post Posted: Wed Dec 01, 2010 6:32 am
Ok i've finally found the problem. 8)
What i originally did was make a small loom about 40 cm long, that i soldered to the correct wires at the back of the headlight. This is because the wires on the LED weren't long enough to reach.
Turns out that one of the wires i used in the loom had no continuity! Must have been broken in the sheath somewhere, and this was causing all the problems.
Replaced that one wire in the loom and all works perfectly now. This was after i tested every joint/bulb/wire with a test light and multimeter before i found it.
Lesson - always use new wires and no beer before hand! :roll: :lol:
My Grand Vitara
Post Posted: Wed Dec 01, 2010 6:55 am
Here's a pic of the back of the headlight and the wiring i've added.
My Grand Vitara
Post Posted: Wed Dec 01, 2010 6:58 am
So who can tell me why that link didn't work? I'm new to photobucket :oops:
My Grand Vitara
Post Posted: Wed Dec 01, 2010 7:04 am
the bits after the .jpeg is what killed it, copy the bottom option in photobucket.
Post Posted: Wed Dec 01, 2010 7:06 am
take 2...
My Grand Vitara
Users browsing this forum: No registered users and 274 guests
