It is currently Fri Oct 16, 2026 8:55 pm
Post Posted: Mon Nov 29, 2010 11:47 am
I am after a little info on the G16A, i need to know the following details if anyone has them hand or has a link to an online service manual.
Spark plug gap and rec type
rec oil and quantity
oil filter (best recommended)
Timing
Any other info of value would be appreciated
Just put the engine into my Sierra last week and need to give it a little TLC.
Also on a side note, is it possible to put the 16V head on a G16A, are they all the same bottom ends?
Post Posted: Mon Nov 29, 2010 12:04 pm
You'll need 16V pistons, otherwise your pistons and valves will become very, very close friends...
I want my old sig back :(
Post Posted: Mon Nov 29, 2010 12:51 pm
not sure if it will make much difference with your questions, but is it EFI or carby?
The G16A came out in both types, although i believe the Carby is the more common
1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
Post Posted: Mon Nov 29, 2010 9:34 pm
It's the carb one.
Vehicle: 03 Jimny
Post Posted: Mon Nov 29, 2010 9:52 pm
Not sure about the timing as i forgot how i did mine but it was some thing like 4th piston TDC turn cam until rotor button firing on no1. Some one will correct me if im wrong.
Post Posted: Mon Nov 29, 2010 10:56 pm
Piston 1 at TDC and rotor button firing on no. 1
Post Posted: Mon Nov 29, 2010 10:57 pm
Damo wrote:
Piston 1 at TDC on compression and rotor button firing on no. 1
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Mon Nov 29, 2010 11:12 pm
Spark plug gap and rec type NGK BPR6EY-11 they come gapped to 1.1mm
rec oil and quantity best 15-40 you can afford, I stick 5l in mine
oil filter (best recommended) Z172 unless you have Aircon or power steerthem maybe Z418
Timing 6-10 degrees BTDC, run as much as you can without pinging
Any other info of value would be appreciated use better than good coolant, even if it means you cant affford to eat for a week
Vehicle: 03 Jimny
Post Posted: Mon Nov 29, 2010 11:57 pm
JrZook wrote:
i was just going by what jas(want33s) said in a thread i read a while ago
Vehicle: LJ50V, SJ70
Post Posted: Tue Nov 30, 2010 1:39 am
G16A Carby? I have NGK BP6ES listed, with alternatives ND W20EX-U, Champion N9YC.
Post Posted: Tue Nov 30, 2010 1:49 am
R for resistor, less radio noise and easier to get, Y is V groove end rather than flat, free horsepower and arent teh later ones all 1.1mm gap?
Users browsing this forum: No registered users and 277 guests
