It is currently Tue Oct 13, 2026 7:34 pm
Post Posted: Tue Nov 30, 2010 9:44 am
I'm just prepairing the front clip and it has been previously re painted and starting to flake off so I will have to take it to bare metal, do I need to use a etch primer ? I'm spraying 2k
My Maruti build, Click WWW
Post Posted: Tue Nov 30, 2010 9:50 am
yes you should use an etch primer ideally.
you can use a single pack etch and two pack over it without a worry.
with etch primer you only need one single lightish coat for most brands.
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Tue Nov 30, 2010 9:53 am
kill rust! you cant go wrong
95 Sierra SJ70 TinTop
Post Posted: Tue Nov 30, 2010 9:59 am
unless you want to paint something else over it again EVER
Post Posted: Tue Nov 30, 2010 10:35 am
or if you don't want a chalky faded paint finish in 2 years.
killrust is shit. :wink:
Post Posted: Tue Nov 30, 2010 10:38 am
Epic fail advise woooooooooo!
Is the rest of the car 2pac?
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Tue Nov 30, 2010 11:12 am
che_guitarra will disagree with that.... :wink:
Post Posted: Tue Nov 30, 2010 12:37 pm
i find acrylic primer to work a treat even when spraying a 2 pac paint.
seems to be more forgiving
Post Posted: Tue Nov 30, 2010 6:36 pm
Thanks for the reply's guy's what's the easiest way to get the shit paint off, will like a 3m pressure pack of etch do it ? Cheers
And yep the rest if tfe car I have painted in 2k
Vehicle: MY2019 Jimny
Post Posted: Tue Nov 30, 2010 10:38 pm
Whatever Laurie used!
Vehicle: 03 Jimny
Post Posted: Tue Nov 30, 2010 11:04 pm
I used a special blade to get my paint of to bare metal. If ur paint is old and cracking it should come off quite easy with this blade. Works best on a long flat panal where u can push it to one end to the other. I tried paint striper but i found this blade alot quicker and easier. Not sure if its the easiest way but it worked for me. Hope this helps
Post Posted: Wed Dec 01, 2010 3:05 am
it is great stuff hay. i pinched a bit and painted my little boat with it. :D
Vehicle: LJ80
Post Posted: Wed Dec 01, 2010 4:49 am
protec 342-1166 barrier green $15.00 per litre
Users browsing this forum: No registered users and 266 guests
