| Painting http://auszookers.com/forum/viewtopic.php?f=5&t=17166 |
| Author: | xedent [ Tue Nov 30, 2010 9:44 am ] |
| Post subject: | Painting |
I'm just prepairing the front clip and it has been previously re painted and starting to flake off so I will have to take it to bare metal, do I need to use a etch primer ? I'm spraying 2k Cheers |
| Author: | ajsr [ Tue Nov 30, 2010 9:50 am ] |
| Post subject: | Re: Painting |
yes you should use an etch primer ideally. you can use a single pack etch and two pack over it without a worry. with etch primer you only need one single lightish coat for most brands. |
| Author: | Sutho [ Tue Nov 30, 2010 9:53 am ] |
kill rust! you cant go wrong |
| Author: | ajsr [ Tue Nov 30, 2010 9:59 am ] |
Sutho wrote: kill rust! you cant go wrong
unless you want to paint something else over it again EVER |
| Author: | shep [ Tue Nov 30, 2010 10:35 am ] |
ajsr wrote: Sutho wrote: kill rust! you cant go wrong unless you want to paint something else over it again EVER or if you don't want a chalky faded paint finish in 2 years. killrust is shit. |
| Author: | JrZook [ Tue Nov 30, 2010 10:38 am ] |
shep wrote: ajsr wrote: Sutho wrote: kill rust! you cant go wrong unless you want to paint something else over it again EVER or if you don't want a chalky faded paint finish in 2 years. killrust is shit. Epic fail advise woooooooooo! Is the rest of the car 2pac? |
| Author: | atari4x4 [ Tue Nov 30, 2010 11:12 am ] |
che_guitarra will disagree with that.... |
| Author: | MrRocky [ Tue Nov 30, 2010 12:37 pm ] |
i find acrylic primer to work a treat even when spraying a 2 pac paint. seems to be more forgiving |
| Author: | xedent [ Tue Nov 30, 2010 6:36 pm ] |
Thanks for the reply's guy's what's the easiest way to get the shit paint off, will like a 3m pressure pack of etch do it ? Cheers And yep the rest if tfe car I have painted in 2k |
| Author: | lump_a_charcoal [ Tue Nov 30, 2010 10:38 pm ] |
Whatever Laurie used! |
| Author: | zooky08 [ Tue Nov 30, 2010 11:04 pm ] |
I used a special blade to get my paint of to bare metal. If ur paint is old and cracking it should come off quite easy with this blade. Works best on a long flat panal where u can push it to one end to the other. I tried paint striper but i found this blade alot quicker and easier. Not sure if its the easiest way but it worked for me. Hope this helps |
| Author: | shep [ Wed Dec 01, 2010 3:05 am ] |
lump_a_charcoal wrote: Whatever Laurie used!
it is great stuff hay. i pinched a bit and painted my little boat with it. |
| Author: | laurie [ Wed Dec 01, 2010 4:49 am ] |
protec 342-1166 barrier green $15.00 per litre |
