It is currently Wed Jul 29, 2026 8:37 am
Post Posted: Sat Dec 04, 2010 1:27 pm
I was just wondering what size optima battery would fit in a vitara and where u put it. also what type of optina would be best to run my fride and stereo onboard pc etc??
Vitara JX 1.6, straight through 2 1/4" exhaust, 2.
Post Posted: Sat Dec 04, 2010 8:19 pm
I use a hilux sized battery from a bus :D 760 CCA and it will run my 40 liter engel for 2 days without charging and still start. The only thing I would do diffently with this set up is rotate the battery so the positive is near the firewall cause i've had to insulate the bonnet to stop it burning! Also just need to upgrade the earth to something a bit bigger then the standard pencil p.o.s
Post Posted: Sat Dec 04, 2010 8:20 pm
p.s This setup was cheap as cause the batterys are only $170 from a bus spares joint, and you need to more your airbox forward about 50mm.
Users browsing this forum: No registered users and 49 guests
