| Water http://auszookers.com/forum/viewtopic.php?f=5&t=17309 |
| Author: | ando_zook94 [ Mon Dec 06, 2010 4:01 am ] |
| Post subject: | Water |
Went thru some big puddles and now she's choking, if water got in what do I do? |
| Author: | gregwatkins75 [ Mon Dec 06, 2010 4:21 am ] |
| Post subject: | Re: Water |
I'd say change all fluids first, pull the plugs out and turn it over for a while, maybe with a bit of oil down plug holes, just to make sure its all back out. |
| Author: | rpmwrx [ Mon Dec 06, 2010 4:21 am ] |
get a snorkel and let the bungs out to drain the water out of the cab... |
| Author: | zooky08 [ Mon Dec 06, 2010 4:28 am ] |
ive always herd that you can wash out small engines with diesel then wash it again with petrol to get rid of the diesel. not sure if this is the case for a car engine tho |
| Author: | dm90 [ Mon Dec 06, 2010 4:28 am ] |
take seats and carpets out and shampoo em before they go smelly and mouldy, change all oils, engine, transmission, transfer case etc. big puddles = |
| Author: | atari4x4 [ Mon Dec 06, 2010 4:33 am ] |
dm90 wrote: big puddles =
| Author: | Scrawny [ Mon Dec 06, 2010 6:29 am ] |
atari4x4 wrote: dm90 wrote: big puddles = Na, you just need to be prepared for some maintenance after You will need to pull the dizzy cap off and dry any moisture in there too. Also, if the water had any kind of mud in it, you will need to clean the rear brakes out before the mud chews them to bits. These are all regular maintenance items so learn how they work and your car will last longer and you will have less dramas with it |
| Author: | ando_zook94 [ Mon Dec 06, 2010 9:36 am ] |
Muddy water got into my carby and stuffed one of the jets:|. |
