It is currently Fri Sep 25, 2026 1:18 am
Post Posted: Wed Dec 08, 2010 12:54 am
The squirters on the old girl are a little sub standard so as a cheap way to kill some time was going to put two more jets with new pumps to get a lot more water onto my windscreen :)
Can anyone suggest a car that has a good stream of Water and pretty common
Vehicle: LJ20 LJ50
Post Posted: Wed Dec 08, 2010 1:05 am
most modern cars have four jets but make sure the ones you get can go high enough cause there is no point getting some which are for a car with a really swept back windscreen
or bling it up
http://www.ryda.com.au/Aerpro-EL5W-Skul ... p/el5w.htm
tons on ebay too
Camels have nice toes
Post Posted: Wed Dec 08, 2010 1:17 am
on my old pootrol, i fitted washer jets to the wiper arms using cut down metal jets from a EA81 4wd Subaru Wagon, a couple of lengths of washer hose, Y junctions & some cable ties.... it would flood the windscreen & mud had no chance of sticking.
Post Posted: Wed Dec 08, 2010 8:11 am
i had some on my zook you can buy them from truck shops i think but my old man used to work for volvo trucks and thats where i got mine
here you go page 22 the part number is 75400
http://www.tricoproducts.com.au/pdf/trico-catalogue.pdf
josh AKA Bazook
Post Posted: Thu Dec 09, 2010 5:58 am
I used VW/Audi pump and jets. Mine came from a SEAT Cordoba (or maybe an Ibiza?) And they are the same pump and jets used in lots of VW/Audi group cars.
The VW pump press fits into the VW washer bottle, but if you pull it out, you'll notice it has a sort or barb on the inlet side that the stock sierra hose pushes onto snugly.
As a result I'm running both pumps - stock sierra into VW. I have excellent washers :D
Fitting these requires two rectangular holes to be cut in the bonnet - I used a dremel with a small cutoff wheel.
I scored two complete pump, washer and hose sets from a pull it yourself wrecker for free.
There's lots of SEAT's in wreckers as they aren't worth anything second hand, and all the bits are VW-Audi generic so quite high quality and well engineered.
Users browsing this forum: Google [Bot] and 132 guests
