Joined: Sun Feb 21, 2010 10:30 pm Posts: 388 Location: bundy
Vehicle: suzuki sierra coily
Posted: Fri Dec 10, 2010 7:54 pm
I have done a RUF awhile ago. Using OME rear Lifted springs. I've mooded the leaf pack and I really happy with the flex i getting. But this has moved my diff 1.5 inches forward. Now my drag link hits and my pitman arm to drag link ball joint fowls on steering link. Will a drop pitman fix this. Or should I move my front diffs rear purches back?
i have done the same thing and get some hitting if i go to fast over bumps, i thought the drop pitman arm might help but couldnt even come close to fitting it because of the angle the steering links. I will be upgrading my front shocks and adding a leaf to make it a bit higher and slightly stiffer which hopefully fixes the issue.
i have done the same thing and get some hitting if i go to fast over bumps, i thought the drop pitman arm might help but couldnt even come close to fitting it because of the angle the steering links. I will be upgrading my front shocks and adding a leaf to make it a bit higher and slightly stiffer which hopefully fixes the issue for me
Users browsing this forum: Google [Bot] and 101 guests
