| WT transfer into coily http://auszookers.com/forum/viewtopic.php?f=5&t=17474 |
Page 1 of 2 |
| Author: | Richo [ Mon Dec 13, 2010 12:20 am ] |
| Post subject: | WT transfer into coily |
Has anybody on here done this conversion and if so is there much to it? I have access to hoist etc so the labour part of the job is no issue. Cheers Richo |
| Author: | 31zook [ Mon Dec 13, 2010 1:02 am ] |
| Post subject: | Re: WT transfer into coily |
rusho(maybe soon), saam, jonno, many times before, have a quick look |
| Author: | ZookiMonsta [ Mon Dec 13, 2010 1:21 am ] |
I did it to my coily, used a WT transfer case, WT transfer mounts, WT jackshaft. You will have to use the WT tailshaft (front/rear/jackshaft) nuts and bolts as the coily transfer case has a thread taped into each flange. Takes about 40mins to do if that! |
| Author: | jonno_racing [ Mon Dec 13, 2010 1:33 am ] |
^^^^^ get new bolts and nilocks m10x35mm |
| Author: | ZookiMonsta [ Mon Dec 13, 2010 1:59 am ] |
Also, I wouldn't bother putting one in unless it's got reduction gears fitted or the coily one is toast. No real gain other than allowing you to fit gears. |
| Author: | Richo [ Mon Dec 13, 2010 3:22 am ] |
yeah cheers for that was planning on fitting some reduction gears to it before fitting. |
| Author: | Richo [ Mon Dec 13, 2010 3:58 am ] |
i just realised the transfer case i got is out of a n/t, does this make a difference?? |
| Author: | tanshi [ Mon Dec 13, 2010 3:59 am ] |
yeah, the flanges that the shafts bolt to are different |
| Author: | Richo [ Mon Dec 13, 2010 7:09 am ] |
Can the coily flanges be fitted to the nt transfer?? |
| Author: | Rusho [ Mon Dec 13, 2010 7:43 am ] |
Richo wrote: Can the coily flanges be fitted to the nt transfer??
I'm glad you asked that question...I would like to know the answer to that also |
| Author: | bagnkat [ Mon Dec 13, 2010 7:55 am ] |
Rusho wrote: Richo wrote: Can the coily flanges be fitted to the nt transfer?? I'm glad you asked that question...I would like to know the answer to that also Rusho, Richo, I'm almost certain they are different. |
| Author: | jonno_racing [ Mon Dec 13, 2010 8:23 am ] |
there diffrent. |
| Author: | Rusho [ Mon Dec 13, 2010 8:26 am ] |
Damn you two |
| Author: | 303zuke [ Mon Dec 13, 2010 10:57 am ] |
ZookiMonsta wrote: Also, I wouldn't bother putting one in unless it's got reduction gears fitted or the coily one is toast. No real
gain other than allowing you to fit gears. The Coily has Hi:1.320 and Low:2.145 ratios, so putting in a stock 1.3 geared case will give him 1.409/2.268, or a stock 1.0 case will give him 1.580/2.511. High range reductions for his Coily would be 6.7% for the 1.3case, or 19.6% for the 1.0 case. Not to be sneezed at, and then there's reduction gears to go further if he wants. |
| Author: | Richo [ Mon Dec 13, 2010 11:50 am ] |
either way the transfer i've got is out of an nt not a wt so it's useless to me anyway as the flanges are different. |
| Author: | Fatzook [ Mon Dec 13, 2010 12:00 pm ] |
Richo wrote: either way the transfer i've got is out of an nt not a wt so it's useless to me anyway as the flanges are different.
Just swap the flanges over mate. Thats all you need to do. Put a wanted ad up for WT transfer flanges. |
| Author: | 303zuke [ Mon Dec 13, 2010 12:12 pm ] |
Or you could keep those flanges on it, and put up an ad for NT driveshafts, 'cos you're going to need whole a new jackshaft anyway. |
| Author: | Fatzook [ Mon Dec 13, 2010 12:14 pm ] |
303zuke wrote: Or you could keep those flanges on it, and put up an ad for NT driveshafts, 'cos you're going to need whole a new jackshaft anyway.
Or that |
| Author: | ZookiMonsta [ Mon Dec 13, 2010 12:46 pm ] |
Fatzook wrote: 303zuke wrote: Or you could keep those flanges on it, and put up an ad for NT driveshafts, 'cos you're going to need whole a new jackshaft anyway. Or that What about the diff flanges? |
| Author: | 303zuke [ Mon Dec 13, 2010 1:03 pm ] |
Half and half shafts. Coily on the Diff ends and WT or NT on the Transfer ends. |
| Author: | Rusho [ Mon Dec 13, 2010 6:17 pm ] |
303zuke wrote: Half and half shafts. Coily on the Diff ends and WT or NT on the Transfer ends.
Not exactly the cheapest away to do it, or the easiest |
| Author: | Richo [ Mon Dec 13, 2010 10:46 pm ] |
Iv'e got the NT jackshaft and might be able to get the driveshafts so thats an idea i can think about, cheers for the input Richo |
| Author: | Richo [ Tue Dec 21, 2010 2:01 am ] |
picked up a NT 1lt transfer with mounts and jackshaft and both driveshafts for $150 so i'm gonna have a crack at the conversion this week without reduction gears to see how big a difference it makes to my coily. I'm currently running 30" stt's so hopefully it gives some better low range! |
| Author: | Rusho [ Tue Dec 21, 2010 2:06 am ] |
Its not going to be that much of a reduction really is it Reduction gears to follow?? |
| Author: | bagnkat [ Tue Dec 21, 2010 2:40 am ] |
Richo wrote: picked up a NT 1lt transfer with mounts and jackshaft and both driveshafts for $150 so i'm gonna have a crack at the conversion this week without reduction gears to see how big a difference it makes to my coily. I'm currently running 30" stt's so hopefully it gives some better low range! Rusho wrote: Its not going to be that much of a reduction really is it !
Good luck with the conversion Richo. Rusho, I reckon you'd be very surprised at the difference. Mine has 30"s, and with the 1L case it makes a huge difference. In anycase even if you're after more gearing, $150 isn't a bad spend for an immediate improvement. Especially considering that for gears you need to do the conversion anyway |
| Author: | Trojan [ Tue Dec 21, 2010 4:10 am ] |
bagnkat wrote: Rusho wrote: Richo wrote: Can the coily flanges be fitted to the nt transfer?? I'm glad you asked that question...I would like to know the answer to that also Rusho, Richo, I'm almost certain they are different. If they are the same as a 1L transfer. Just do as i did. Take the original flanges and cut a section of about 5-10mm (can't remember exact amount) of the splined section off, this becomes a spacer. Slip it onto the output shaft, then slip the coily flanges on. It will space them out enough so they don't foul on the case body. |
| Author: | bagnkat [ Tue Dec 21, 2010 4:23 am ] |
from memory the spline count / shaft diameter was different. |
| Author: | ZookiMonsta [ Tue Dec 21, 2010 8:19 am ] |
Just sell the NT case and buy a donor WT for the reduction gears... I picked mine up for $90, you could get atleast half that for the NT case. |
| Author: | Richo [ Tue Dec 21, 2010 10:42 pm ] |
ZookiMonsta wrote: Just sell the NT case and buy a donor WT for the reduction gears... I picked mine up for $90, you could get atleast half that
for the NT case. WT t/fers are like rocking horse shit in WA and when you do find em they sure aint $90 and why would i just sell a NT case for $45 when i just paid $150 for it |
| Author: | Fatzook [ Wed Dec 22, 2010 7:54 am ] |
Richo wrote: ZookiMonsta wrote: Just sell the NT case and buy a donor WT for the reduction gears... I picked mine up for $90, you could get atleast half that for the NT case. WT t/fers are like rocking horse shit in WA and when you do find em they sure aint $90 and why would i just sell a NT case for $45 when i just paid $150 for it X2. keep the NT case and slap some gears in it. Worry about the flanges later |
