It is currently Fri Oct 09, 2026 12:48 pm
Vehicle: 98 Maruti
Post Posted: Wed Dec 22, 2010 10:08 am
i picked up a 92 sierra the other day and the speedo is all over the place, it moves up and down constantly untill i get over about 80-90 then it reads 130, i did a search but didnt get much only a bit about re oiling the speedo cable.
would buying a new speedo cable fix the problem? or is it somthing to do with the tranfer or tacho?
cheers
Post Posted: Wed Dec 22, 2010 6:42 pm
Oil the cable or replace it.
Post Posted: Wed Dec 22, 2010 9:34 pm
my speedo does the same thing, only till i get to 60kph
then it;s fine. it is a second hand one though.
Post Posted: Wed Dec 22, 2010 11:10 pm
Mine is doing this as well. What oil do you use? Where do you locate the cable to oil?
Post Posted: Thu Dec 23, 2010 8:09 am
Remove the cable from the car.
It runs from the transfer case through the floor at the passengers footwell and behind dash to the speedo head.
Hang it from the clothes line and squirt oil into the top... Repeat every 10-15 minutes until oil is coming out the bottom.
Refit to car.... If speedo is still jumpy then the inner lining of the sheath around the cable is stuffed and it's time for a new one.
Post Posted: Thu Dec 23, 2010 11:40 pm
ohh I know the one your talking about :) . Thanks for that mate... another little job to do!
Post Posted: Fri Dec 24, 2010 3:57 am
i had the same problem so i got a new one turns out it just wasnt seated in the tranfercase properly
Post Posted: Sun Dec 26, 2010 7:35 am
mines got a massive hole in the side outside case of the speedo cable. Whats the cheapest place to get a new one?
Post Posted: Sun Dec 26, 2010 11:44 am
ebay thats where i got mine but its a really cheap and nasty one
Post Posted: Sun Dec 26, 2010 10:31 pm
Ive got one here. who wants? $15 and ill post it.
Post Posted: Mon Dec 27, 2010 2:03 am
I get the same problem on my 97 Sierra, not too bad, generally wobbles within about 10-15km, so I just figure I'm doing something somewhere around the middle.
Not sure if I should try to take it off and oil it, since I'd probably forget where to put it back or forget to put it back at all, or something cute like that :? Is it worth getting a new one, or just stick to a cheaper one from ebay or similar?
Post Posted: Tue Dec 28, 2010 9:23 am
cheap and nasty is my middle name:)
Users browsing this forum: No registered users and 167 guests
