It is currently Sun Oct 11, 2026 1:43 am
Post Posted: Thu Dec 23, 2010 11:48 pm
hey guys im half way thru doing my steering box but i cant get the steering arm to come off. does any one have any tips for me .....im thinking about just cuttin the stupid thing off with the grinder ..... im also pissed at it lol.
Any help would be great.
Post Posted: Thu Dec 23, 2010 11:53 pm
the pitman arm?
buy a puller. they can be a bitch to get off.
Post Posted: Thu Dec 23, 2010 11:55 pm
Pitman arm puller.
Bearing puller.
Hyd bearing puller.
Tapping whith a hammer helps with these options
Heat also helps with these options
Or if you have a spare off already, grind a slot in the shit one, Then BFH
Post Posted: Fri Dec 24, 2010 12:03 am
whats a pitman puller worth
Post Posted: Fri Dec 24, 2010 12:08 am
super cheap.
the price will vary
Post Posted: Fri Dec 24, 2010 12:15 am
Did you know you can shop online? http://www.supercheapauto.com.au/online ... ?pid=12554
Post Posted: Fri Dec 24, 2010 12:20 am
Get a heavy lump hammer and hit the edge of the pitman arm around where the tappered shaft of the ball joint is. Don't hit the joint, just hit the end of the pitman arm. The shock loading may free it up. You won't need to put your back into it, but 10 or 20 good firm hits should see it come free. If that fails, you'll need a tie rod puller :cry:
Post Posted: Fri Dec 24, 2010 12:53 am
OH i read it as pitman arm. LOL
Normally a big bit of bar down through engine bay and a good hammer will knock it out. May damage thread alittle if your hitting the thread. but its just the end. Fix with a file.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Fri Dec 24, 2010 1:36 am
At $52 you might be better off getting a bearing puller, they arent much more and are more flexible. I used borrowed one several times when doing my power steering. did the job well.
Post Posted: Fri Dec 24, 2010 2:30 am
thanks heaps for the help lads, ended up going for the pitman arm and also went and got the puller, all up i think 3.5 hrs lol i couldnt beleive it i have changed gearboxes quicker than that. Was also going to do the diff breathers, but i cant be F#%ed
Post Posted: Fri Dec 24, 2010 3:56 am
Me too... :?
Post Posted: Fri Dec 24, 2010 4:51 am
ah so it was the pitman arm.. :lol:
Post Posted: Fri Dec 24, 2010 4:55 am
That has to come off to "re-build" the box....
Post Posted: Fri Dec 24, 2010 7:45 pm
wow its like driving a different car now hahahahah ....except my steering wheel is on the piss
Users browsing this forum: No registered users and 265 guests
