It is currently Tue Oct 13, 2026 9:44 am
Vehicle: 03 Jimny
Post Posted: Fri Dec 24, 2010 8:46 am
motor has had a full rebuild, slapped it into the car today.
hooked every thing up. then had problems with the dizzy, had no spark.
so i fiddled around with it and has got spark now.
but now it wont start :(.
theres spark and theres fuel, and the timming is wright.
any body know whats happen. it has lost me :evil:
Vehicle: Nissan
Post Posted: Fri Dec 24, 2010 8:49 am
are you sure that your timing is on number 1 and not 4 :wink:
Pearce-toff Racing
Vehicle: 03 Jimny
Post Posted: Fri Dec 24, 2010 8:52 am
yep timming is spot on
Vehicle: Nissan
Post Posted: Fri Dec 24, 2010 8:58 am
what did you do in teh rebuild? is it a standard engine???
Pearce-toff Racing
will it fire with a little fuel down the carb??
if not your spark is wrong
Vehicle: 03 Jimny
Post Posted: Fri Dec 24, 2010 9:04 am
the head got recon(valves, stem seals, guids sleves,shaved)
block got bored to 40 thou with matching piston and ring, also shaved.
motor is a g16a with g13ba head
put fuel down the carb doesnt really do ny thing, after a few cranks it back fires out of the carb
Post Posted: Fri Dec 24, 2010 9:09 am
timing is 180 out
Post Posted: Fri Dec 24, 2010 9:13 am
Timing (either cam or diszzy) is DEFINATELY out of wack.
Check both again.
Vehicle: 03 Jimny
Post Posted: Fri Dec 24, 2010 9:50 am
royce is right, turn dizzy 180, and its started.
a lil bit rough, im guessing im one tooth out on the dizzy
Vehicle: Nissan
Post Posted: Fri Dec 24, 2010 10:33 am
:wink:
Pearce-toff Racing
Users browsing this forum: No registered users and 207 guests
