It is currently Thu Oct 15, 2026 3:06 am
Post Posted: Thu Dec 30, 2010 7:40 am
Can these be bought,
without buying an entire suspension kit from UK?
UK kit is made in Aus but having no luck hunting them down.
May try the old school way, and go to a few Auto shops :)
Do we have any AZ bush suppliers?
Thanks All
christover
Post Posted: Thu Dec 30, 2010 7:51 am
you could probably put a camber pin in the rear lower control arm pivot, would do the same thing, note it will adjust the camber too
why do you need it?
Post Posted: Thu Dec 30, 2010 8:05 am
why do you need it?
A less barbaric way of achieving the Hagen Widening Mod.
Only want a few millimetres, not a whole 25mm.
To give the rhs axle a bit more slack, so it is easier to remove.
May not actualy need it yet, just a back up plan if I do later.
Post Posted: Thu Dec 30, 2010 8:10 am
what bottom arms do you have? some you could slot the balljoint holes to move it all out a bit and weld some washers in the new spot
remember youll need to do it both sides to keep the alignment nice
Post Posted: Thu Dec 30, 2010 8:17 am
Welding steering and suspension parts is way out of my abilities.
But will look into that, if needed.
No idea what arms, I assume stockers.
Doubt I will need to do anything,
I have clearance for the cv joint and stubby.
Stuck at home for a week, brain can't stop scheming :D
Post Posted: Thu Dec 30, 2010 8:22 am
by which arm, there are 3, you could have one of 2, one the balljoint attaches to teh arm on one side only, the other it attaches on both sides, the balljoint sort of slips into the arm
Post Posted: Thu Dec 30, 2010 8:32 am
It bolts onto one side only, on the bottom I think.
I better go look
Post Posted: Thu Dec 30, 2010 9:05 am
Post Posted: Thu Dec 30, 2010 9:08 am
slot 1 hole, then you can undo 2 bolts, slide it out, replace and bolt it back together?
Post Posted: Thu Dec 30, 2010 9:09 am
i wonder if bruce can knock out an offset bush or if something can be adapted from another vehicle, the only ones i've see are for the radius arms on teh land cruisers & patrols
Post Posted: Thu Dec 30, 2010 9:15 am
It didn't look like there was enough room to slot any, but it is dark, so will look properly one day
Post Posted: Thu Dec 30, 2010 9:16 am
Superpro do aq kit for entire suspension, Bits4Vits sell it (made in Aus)
So they exist, somewhere.
Post Posted: Thu Dec 30, 2010 9:23 am
superpro are by fulcrum
Post Posted: Thu Dec 30, 2010 9:26 am
look what I found
http://203.31.191.243/fulcrumCat/
Post Posted: Thu Dec 30, 2010 9:29 am
Found a few sites that linked fulcrum and superpro, including supercrap autos,
no listing on supercheap for the castor correction types.
Still hunting
Post Posted: Thu Dec 30, 2010 9:31 am
look up :)
fulcrum are a company, like Pedders but useful (jut dont let em drive your Porsche)
Post Posted: Thu Dec 30, 2010 9:34 am
look up :)
Was there once already, but searched wrong, found it this time, many thanks
Post Posted: Thu Dec 30, 2010 9:36 am
I could knock up a bush with no hole. (like just pour a rod of polyurethane) and you could drill ya own hole that is offset?
Post Posted: Thu Dec 30, 2010 9:42 am
yeah that could work, but getting 2 hole exactly the same could be a challenge, but it looks like royce has found a solution.
those superpro ones look alright as the sleeve is offset, rather than the hole being offset & having less material on one side.
Post Posted: Thu Dec 30, 2010 9:45 am
SPF0920AK
Bit dear so far, but still looking
Post Posted: Thu Dec 30, 2010 8:56 pm
Bit4Vits does sell them separately, and a better price delivered from UK, than I any I found so far. They wasn't that hard to find, unsure why I didn't spot them before.
http://www.bits4vits.co.uk/store/VITARA ... d_143.html
Post Posted: Thu Feb 10, 2011 8:03 pm
I have ordered a set of these caster correction bushes,
along with a matching set of stock fronts.
Should help with steering,
but also give a little more firewall clearance,
and more room when needing to change cv/axle
Damn pretty color :)
Bits4Vits own brand, cheaper than superpro,
hopefully as good in quality.
Users browsing this forum: No registered users and 971 guests
