http://auszookers.com/forum/
Power Window Problem
http://auszookers.com/forum/viewtopic.php?f=5&t=1787
Author:  magnat [ Tue Feb 26, 2008 9:30 pm ]
Post subject:  Power Window Problem
My Rear power Windows don't work.. not sure what Vibrated loose but both rear windows wont work...
The Front Passenger side and drivers side work and with the Window lock engaged the Passenger front doesn't work.. but the rears dont work regardless of if the Window lock is down or Off..
So what could be the problem???
Author:  steve [ Tue Feb 26, 2008 9:43 pm ]
Post subject:  Re: Power Window Problem
fuse or plug to the rear? :?
Author:  oscar [ Wed Feb 27, 2008 12:38 am ]
do they make a noise when u are trying to lift or lower?
put you ign on, see if your red lights dim when u are tring to use switches. not running
Author:  magnat [ Wed Feb 27, 2008 2:12 am ]
Switches all dim the Start light... I have a Feeling its a dicky Window lock button... Brilliant!!!!!!!
Author:  royce [ Wed Feb 27, 2008 2:36 am ]
if they dim there is power to the motors as they are drawing current
SQ416_1of2.pdf in the downloads section has pinouts on page 575, knock yourself out :wink:
Author:  sp1086 [ Wed Feb 27, 2008 2:43 am ]
Royce Posted:knock yourself out
BANG!!! 8O
:roll: :roll:
Author:  oscar [ Wed Feb 27, 2008 10:25 am ]
start car, slam the crap outta ur doors while usuing switch.
check its dimming for up and down
Author:  oscar [ Wed Feb 27, 2008 10:26 am ]
Author:  rodw [ Sun Mar 02, 2008 12:05 am ]
Magnat,
I have got some window switches going by pulling them out and spraying liberally with Innox lubricant and blowing out with compressed Air. Innox is like WD40 except is non-conductive so it is OK to use on electrical stuff.
While you have got it out, a multimeter will tell you if the swich works or not before you go to town on it.
The other fault I have had with power windows is a dicky solenoid on the regulator motor itself. I could hear the thing clicking, but the motor did not turn on. I fixed this by buying a new regulator from a wrecker...
Rod
Author:  oscar [ Sun Mar 02, 2008 12:48 am ]
switch obviosely works if light dims so u need to tap motor with hammer softy on mech part. or try slamming door like i said b4 taking trim off. do all this with car running and holdind switch direction u want it to go.
Author:  magnat [ Sun Mar 02, 2008 4:54 am ]
Well.. I powered the Door motors and they all worked fine
So it has to be a dicky window lock button as the front window works fine, Hit the Window lock button, then hit it again then they don't work on the rears...
Press the thing repeatedly then the Rear windows work temporarily..
I checked all the wiring for shorts and nothing is exposed or corroded..
How ever there is one hell of a Nasty screach on the Front Passenger side window the part which scraps moisture off the window may have a bit of Crud build up...
Author:  oscar [ Sun Mar 02, 2008 2:59 pm ]
if ur front passenger works its not ur window lock.
spray the crap outta contacts with "contact cleaner" or pull it apart and clean them.
Or take the switch to a auto elec, i would of charged 50 bucks to fix a switch.
u can bridge the window lock button too. so if u dont want it that can be done easily
Author:  royce [ Sun Mar 02, 2008 3:17 pm ]
could be the switch cause its dual throw, one for the front one for the back, the back section could be grubby
jsut dip it all in petrol and light it up, no hang on thats for spark plus :P
