It is currently Fri Oct 09, 2026 5:19 am
Vehicle: 06 Jimny
Post Posted: Fri Dec 31, 2010 12:09 am
love my 2006 Jimny but the left rear coil seems to sag with the result of reduced guard clearance, after 75000 kl is this something normal to standard suspension. I have followed some of the tech threads and I am now more confused than ever.
Ok I can change the rear coils as a pair but should the fronts be changed as well as a set to get the correct spring rates?
As I mainly tour, dont need too much lift so thought about EFS coils all around with 25mm lift.
Tough Dog have 40mm lift.
Trying to keep the cost down can I keep the standard shocks at these lifts?
Has any one had anything to do with polyair suspension on a Jimny to stop a sagging rear end when the car is loaded?
Any advice appreciated.
Post Posted: Fri Dec 31, 2010 12:15 am
If you are into touring, i would go for the OME 40mm lift as it is very good ride.
Post Posted: Fri Dec 31, 2010 3:52 am
My 04 GV with 55,000kms had three out of the four factory shocks completely gone. Replaced with Bilsteins Shocks/Struts and Dobinsons Springs and result was brilliant.
Vehicle: Jeep
Post Posted: Fri Dec 31, 2010 5:46 am
Normal suspension will drop a bit, but that sounds like alot, so i would say, not so normal... and i am guessing its out of warranty...
I just had a quick look thru ebay, found these Tough Dog springs only, at $440 + free delivery -
http://cgi.ebay.com.au/SUZUKI-JIMNY-TOU ... 56416793d8
And PM sent
Post Posted: Fri Dec 31, 2010 5:48 am
how much weight are you sticking in teh back?
but 75000km is pretty well at the end of its life for springs and shocks
Post Posted: Fri Dec 31, 2010 5:58 am
Sounds like you've got a bit of gear in the back. Most OEM Suspension isn't designed to take all the weight of gear such as Fridges, tents Etc... fully loaded for a trip.
I would recommend to anyone who's looking to do some serious touring to upgrade the suspension all around just to something more heavy duty. even if your not after the height.
Stocker
Vehicle: 06 Jimny
Post Posted: Fri Dec 31, 2010 7:46 am
Thanks for the input.
Will continue the research.
No fridges in the back found too heavy in weight and cost, I use 2 small 10ltr esky's and cryovac and freeze barbi meat.
Any one ever used the air bag suspension to help level up the rig?
And Happy New Year to All.
Post Posted: Fri Dec 31, 2010 7:55 am
Your better off with spring's, spring's can't deflate..
Post Posted: Fri Dec 31, 2010 7:58 am
I have the OME 40mm lift and when out camping have a fridge and 90 amp deep cycle battery plus other gear in the back and the height is great. Handles the weight real good.
Paul
Post Posted: Fri Dec 31, 2010 8:02 am
Paul
I agree with you OME is the kit for touring.
Vehicle: 06 Jimny
Post Posted: Sat Jan 01, 2011 7:16 am
Thanks for the input, looks like the OME set up is the way to go, I believe in doing it once and doing right, will try to find a good price, and then not tell the wife. Nothing worse than a sagging bum which is what I put up with now.
Post Posted: Sat Jan 01, 2011 7:26 am
Yeah probably be careful when talking about sagging bums with the wife :)
Vehicle: 06 Jimny
Post Posted: Sat Jan 01, 2011 7:42 am
Point taken, in that case I shall have to fix my droop quietly
Users browsing this forum: No registered users and 246 guests
