It is currently Fri Oct 09, 2026 2:32 pm
Post Posted: Tue Jan 04, 2011 6:26 am
Just can't figure this out,
When key is on the on position the light for battery doesn't show, which ever way that I put the two wires, I know the globe works.
Testing the two wires they are both 12v ?
Anyone be able explain how the sence wire works?
Can I run a new one ?
My Maruti build, Click WWW
Post Posted: Tue Jan 04, 2011 7:03 am
does the globe light up in the dash when either of the 2 wires are probed with a test light (must be a globe test light not a LED one)
Post Posted: Tue Jan 04, 2011 7:10 am
I don't have a test light just a multi metre?
Post Posted: Tue Jan 04, 2011 7:48 am
you need to use a test light to check it.. it wont work with a multi metre.
there is a good chance that the alternator is stuffed .. was it new? or 2nd hand??
the sense wire is just a referance for the alternator as to what the battery voltage is.
Post Posted: Tue Jan 04, 2011 7:54 am
But is the sense wire from tacko ment to be 12v ? I thought i read it was 5v or something ?
Yes second hand alternator.
Vehicle: Nissan
Post Posted: Tue Jan 04, 2011 8:11 am
have you tryed swapping the two wires around on the alternator?????
Pearce-toff Racing
Post Posted: Tue Jan 04, 2011 8:19 am
if its doesnt work either way its in the alt, pretty common
Post Posted: Tue Jan 04, 2011 8:33 am
Ok, does it mean alt is done or just that the light won't work ?
Vehicle: Nissan
Post Posted: Tue Jan 04, 2011 8:39 am
my light doesnt work but i got it tested and its fine :wink:
Pearce-toff Racing
Post Posted: Wed Jan 05, 2011 4:52 am
Just bought a test light, conected aligator clip to earth and probed the two wires, the batt light one is not as bright but doesn't light the dash light.
Vehicle: G16b 83
Post Posted: Wed Jan 05, 2011 5:44 am
http://www.youtube.com/watch?v=PZjvoysAn_4 this helped me when i did mine
Post Posted: Wed Jan 05, 2011 9:21 am
it will light the dash but very dim... has to be night time to really see it or cover the dash with a towel.. will light the test light dull as well. if it doesnt light the light in the dash then there is a problem
if all is good then put that wire it the right pin (when looking at the alternator with the pulley facing the ground) and the other wire into the left
connect main battery wire to alt
start and see if it charges. if light does not come on and go out once running then there is an alternator problem.
Post Posted: Wed Jan 05, 2011 10:22 pm
Ok the light comes on not as bright, so must be alt, cheers guys
Users browsing this forum: Google [Bot] and 148 guests
