It is currently Mon Oct 26, 2026 12:51 pm
Post Posted: Tue Jan 04, 2011 9:05 pm
GV 2000 model, V6 Auto
Have a very noisy fan belt when start from cold. Have replaced both fan belts and made adjustment but this didn't make any difference. Any one have any suggestions?
Post Posted: Tue Jan 04, 2011 9:08 pm
You sure it's tight enough? I know you stated that you made adjustment but I had same prob when I had by 2000 Auto GV and alto the belt seemed tight I nipped it up some more and it never happened again.
Post Posted: Tue Jan 04, 2011 10:44 pm
What sort of noise? Squealing?
Remove the belts one at a time and start the engine to determine which belt is making the noise - whilst you have the belts off spin the idler/tensioner pulleys by hand, replace any that don't rotate smoothly & silently.
It's not unusual for belt squeal to occur after a cold start due to the added load on the alternator as it recharges the battery, this is typically caused by a loose or worn belt and if left long enough the pulley may develop a glaze which leads to further slipping, so if it is your alternator belt that is squealing, examine the pulleys for glazing.
Vehicle: LWB Sierra & XL7
Post Posted: Tue Jan 04, 2011 10:52 pm
This works very well.
Vehicle: SWB Vit & LWB GV
Post Posted: Wed Jan 05, 2011 12:41 am
^^ this didn't work for me.
I used this
put a little bit on all the pulleys and you'll be laughing. With A/C off, I get a tiny squeal on cold start-up (~1sec) with A/C on and lights on, (~2secs) but then it goes away.
My mechanic suggested this as my A/C pulley is a little off centre.
Like others have suggested, the belts need to be f'n tight.
T
Vehicle: Daisy
Post Posted: Wed Jan 05, 2011 5:54 am
^^^ I know it works, but it just doesn't seem right to me to basically mask the fact that it's slipping by greasing it so it doesn't damage the belt/pulley while it slips.
My old man suggested soap the other day, just rub a cake of soap on the pulley/belt a little bit. Same principle as the grease, nowhere near as proper a fix...
Post Posted: Wed Jan 05, 2011 6:26 am
He's on the money, they need to be TIGHT, a leaver may be needed, like a lok screw driver or the like's, but HAVE to be tight. Multi rib is not like the ole V belt's, multi need tension on em..
Post Posted: Wed Jan 05, 2011 6:27 am
This is glue in a pray can...
Post Posted: Wed Jan 05, 2011 7:11 am
steak_knife wrote:
This is man glue in a pray can...
8O
Post Posted: Sun Feb 06, 2011 7:13 am
Well i had the same problem and had a read here through all the posts and thought the candle idea seemed like the best option....
So i fabricated my own "candle wax belt noise reducer 3000" (it doesn't get much dodgier than this) this thing worked an absolute treat...... yes it's a tea candle screwed to the end of a thin offcut of ply..... I wonder how long it will take the wife to realise one of her candles is gone.....
Noise is completely gone !
Post Posted: Mon Feb 07, 2011 2:46 am
mine was just giving me the shits... so i just leant on the leaver bar and tightend it up.. got about another 14mm on the adjuster.. no more sequel
Vehicle: 2001 Jimny M13a
Post Posted: Mon Feb 07, 2011 5:17 am
I replaced mine. They squealed. I tightened them up more. they still squealed. So I tightened them right up and now they don't squeal.
Shame 60% of the belt is shredded all over the engine bay already but hey, I know how tight it needs to be next time.
Users browsing this forum: Google [Bot] and 349 guests
