It is currently Tue Oct 27, 2026 3:27 am
Vehicle: 1993 Sierra 1.6 efi Vit motor,
Post Posted: Mon Feb 07, 2011 3:00 am
Exedy list 2 clutches for SJ413 Sierras -
SZK6474 and SZK6293. Anybody know which is the ciorrect one to use?
Also which are the best T/C mounts to use, I have gone thru 5 in the last 2 months, mainly the Mazda MT8135 ones? This is really annoying as I have hardly put any stress on them especially the last 2, one was even on a downhill run in low range.
Adventure before Dementia
Post Posted: Mon Feb 07, 2011 3:02 am
szk6293... pretty sure
Yeah Cheers Kent~!
Post Posted: Mon Feb 07, 2011 3:03 am
i think it will depend on which gearbox you have. there are two, with different spline counts on the input shafts i believe.
most of the time is best to pull the clutch out before buying it
Post Posted: Mon Feb 07, 2011 4:35 am
yeah count your splines
My Maruti build, Click WWW
Vehicle: Zookless
Post Posted: Mon Feb 07, 2011 4:39 am
x3 count the splines.
Why are you using the Mazda mounts for the t-case? Sounds like they are weaker than the stock mounts.
Most people run stock mounts, or stock mounts lifted slightly, or Just-Cruizin's bolt through, lifted mounts.
Post Posted: Mon Feb 07, 2011 4:44 am
x2 im hard on mine and they are still perfect
Post Posted: Mon Feb 07, 2011 5:23 am
or make some out of 1 inch door stop rubbers a bolt and some shock rubbers top and bottom
Users browsing this forum: No registered users and 365 guests
