| rear demister question http://auszookers.com/forum/viewtopic.php?f=5&t=18069 |
| Author: | dougies_tx5turbo [ Fri Jan 07, 2011 11:35 am ] |
| Post subject: | rear demister question |
my rear door does not have a demister on the glass but i have got wires connecting up for a demister. can you get a demister that sticks on to the rear glass? if so where could i find one? rear demister question Is a 1L fuel tank the same as a 1.3L narrow track fuel tank. (short wheel base) Yes I have complete wide track diffs front and rear and brake lines, would i still need to get extended brake lines? Are you fitting them to a NT? If so, then yes. When i bought the zook the guy said the t-case was rebuilt it looks like it has but my question is how to know if it has reduced gears You would know as soon as you drove it in low range. What do i need to put a 1L t-case with a switch in my 1.3L narrow track Swap the flanges. Straight bolt in. Whats the best way to clean my fuel tank |
| Author: | Fatzook [ Fri Jan 07, 2011 11:41 am ] |
| Post subject: | Re: few question |
dougies_tx5turbo wrote: Q1. Is a 1L fuel tank the same as a 1.3L narrow track fuel tank. (short wheel base) Yes
Q2. I have complete wide track diffs front and rear and brake lines, would i still need to get extended brake lines? Are you fitting them to a NT? If so, then yes. Q3. When i bought the zook the guy said the t-case was rebuilt it looks like it has but my question is how to know if it has reduced gears You would know as soon as you drove it in low range. Q4.What do i need to put a 1L t-case with a switch in my 1.3L narrow track Swap the flanges. Straight bolt in. |
| Author: | dougies_tx5turbo [ Fri Jan 07, 2011 12:09 pm ] |
thanks for all that Fatzook would like to help with your questions but im unexperienced |
| Author: | Fatzook [ Fri Jan 07, 2011 1:06 pm ] |
dougies_tx5turbo wrote: thanks for all that Fatzook would like to help with your questions but im unexperienced
Thats alright mate. We never stop learning |
| Author: | dougies_tx5turbo [ Sat Jan 15, 2011 9:51 am ] |
| Post subject: | Re: cleaning fuel tank |
quick question i need to no |
| Author: | Marlando [ Sat Jan 15, 2011 10:41 pm ] |
I took a fuel tank that had been sitting for a few years full of sludge etc, to a radiator shop and they flushed it out, they have the facilites and chemicals to deal with it. Cost was about $70. |
| Author: | dougies_tx5turbo [ Sun Jan 16, 2011 12:51 pm ] |
can not sleep baby is upset with teething and my f*@ked up wisdom teeth are coming out so i found this http://www.auszookers.com/index.php?nam ... ic&t=17154 but not much help the tank was full of water when i got the car, ive drained it but should i use something to clean out the water? example metho... |
| Author: | Teracis [ Sun Jan 16, 2011 6:36 pm ] |
I just used an oil pan and a small amount of fuel. I took the sender out and poured in some fuel and sloshed it around, poured it into the oil pan. Repeated that till what came out was clean (two goes with bugger all fuel, yours might take longer) and then drained the oil pan into a jerry that already had rooted fuel in it. Haven't got rid of the fuel yet |
| Author: | neofitou [ Sun Jan 16, 2011 11:08 pm ] |
You can only swap the flanges if its a 1L with the 4WD light otherwise your making mixed unis instead. |
| Author: | eXc450 [ Sun Jan 16, 2011 11:24 pm ] |
I had to clean mine from scratch years ago. The best way is to use water and hydrochloric acid (pool shop). This will take it back to bare metal and will rust again VERY quickly, so you need to then line the tank with another product which I don't remember now...but you can get it online if you search. Make sure you get a mask and filters though cause it's some pretty nasty chemicals. edit : see here for my thread on another forum http://www.skylinesaustralia.com/forums ... try3698609 |
| Author: | dougies_tx5turbo [ Sun Jan 30, 2011 8:45 am ] |
| Post subject: | Re: rear demister question |
demister question |
| Author: | fordem [ Sun Jan 30, 2011 2:51 pm ] |
They used to be fairly common a few decades back - but it's been a long time since I've seen one for sale - and my experience with them has been that the self adhesive terminals don't stay on the glass, so the foil tears rendering them unuseable, I never had one that lasted more than a few weeks. Here's one from a place in New Zealand ... http://www.griffiths.co.nz/Shopping/ProductList.asp?FromCategory=120&ToCategory=120 And another closer to home ... http://www.ultraparts.com.au/auction/3173638/UNIVERSAL_REAR_WINDOW_DEMISTER_KIT_.._BRAND_NEW/ |
| Author: | want33s [ Sun Jan 30, 2011 8:47 pm ] |
I have several tintop rear windows with demisters... Bring your car to me and I'll swap your window for a demister version for $40. Fitting included. |
| Author: | dougies_tx5turbo [ Mon Jan 31, 2011 11:36 am ] |
Fatzook wrote: dougies_tx5turbo wrote: thanks for all that Fatzook would like to help with your questions but im unexperienced Thats alright mate. We never stop learning Well like Fatzook said "we never stop learning" my big bro came out and helped me with it, itz all done now thank for the help again really do appreciate the offer want33s |
