It is currently Sat Oct 10, 2026 12:44 pm
Post Posted: Sat Jan 08, 2011 3:18 am
I'm wondering what people have done with regards to fitting a tensioner pulley for power steering to the G16B. I've got the 1.6 fitted to the Sierra and have just installed the Vit PS'ing. Did the G16B ever come without aircon and a tensioner pulley? Is there anything I can use that will bolt straight on to do the job?
Cheers,
Jimmy.
Post Posted: Sat Jan 08, 2011 3:20 am
does your mounting bracket not have a slotted mount for the bottom bolt?
Post Posted: Sat Jan 08, 2011 3:55 am
All Vitaras had slotted brackts on the pwr steer pump bracket. Where air con is fitted there is a bolt hole just in from the slotted bit and the a/c compressor adjusts the belt.
I perfer to use jimney set up and space the top bracket to fit the 1.6, is alot neater and gets the pump closer to the engine so the rad bracket is not such in the way
Suzuki is my way of life.
Post Posted: Sat Jan 08, 2011 4:11 am
Hmmm, i'll have another look. I didn't notice a slot on the bottom of the mount but I'll go have another look under the car.
Users browsing this forum: Google [Bot] and 148 guests
