It is currently Fri Nov 20, 2026 10:42 pm
Vehicle: 75 Cruiser
Post Posted: Tue Jul 25, 2006 5:38 pm
and so i was making brm brm noises and pushing the car around the back yard and the arb air line was hanging down on the ground and went under the wheel and snapped in half.
.... and i need to make the rear air line longer because it's in the lwb now, so the question is,
Can you buy lengths of the blue air line and and fit it yourself to the diff end and stick the thingy on the compressor end? or do they come all ready made up? and are there better places than arb to get this stuff from?
Vehicle: 1994 Hard Top Sierra
Post Posted: Tue Jul 25, 2006 5:41 pm
u can do it ur self its easy ive done it and u can buy the blue air line um not sure about where else but i think boab has blue line
hope this helps abit steve
me not very smart at tech :oops:
Jason
Navigator for Team Casper
Vehicle: 75 Cruiser
Post Posted: Tue Jul 25, 2006 5:50 pm
cool, you can show me! :lol:
I could probably just use te the rear length on the front and get a new length for the rear.
Post Posted: Tue Jul 25, 2006 6:12 pm
yeah you have to buy a full kit with new fittings and stuff, somebody has one spare but they probably want to keep it for casper :wink:
or you can change to more common 6mm and quick release fittings both ends, fair bit cheaper and fixable, I'll just have to find where I wrote down what bits you need
Post Posted: Tue Jul 25, 2006 6:23 pm
Don't think I have the blue line Royce. I keep the 6mm black stuff and some spare fittings but I think I gave (I know I know) the blue line to Jock for some reason. I'll look tonight Steve and see what I have. If I have it you can have it. :-)
Post Posted: Tue Jul 25, 2006 6:25 pm
we gave it to jock for his landcruiser for some reason and we dont have any here i just finished looking
Jason
Post Posted: Tue Jul 25, 2006 7:01 pm
ok, I'll figure ou twhat bits are what again and send you a quote :wink:
Vehicle: 75 Cruiser
Post Posted: Tue Jul 25, 2006 9:45 pm
i'm still waiting for a quote for those full roof top flashing light units like the tow trucks have :roll: ... or did i get that? can't remember :oops:
Post Posted: Tue Jul 25, 2006 9:53 pm
yeas you got it was about $1100
Vehicle: 75 Cruiser
Post Posted: Fri Jul 28, 2006 2:45 pm
How's the goods coming along? Does the service man come around and install the stuff too?
Post Posted: Fri Jul 28, 2006 3:26 pm
oh yeah thats right
umm yeah I'll have a look, like your in a rush anyway :wink:
Vehicle: 75 Cruiser
Post Posted: Sun Jul 30, 2006 9:57 pm
Today i pulled the line fittings apart. The brass tube thing is broken in half and there was a hole in the air line, i was wondering where the leak was. This happened after a log jammed up under the car.
Post Posted: Sun Jul 30, 2006 10:06 pm
the brass braking is common aprently, the little round brass bit is also throwaway once it has been used
Vehicle: 75 Cruiser
Post Posted: Sun Jul 30, 2006 10:11 pm
ahh yeah, tried to get the round brass this back on the tube but it seems impossible, it must get squashed or something when it's tightened up?
I think they call that bit an Olive, in Plumbing
Post Posted: Sun Jul 30, 2006 10:16 pm
yep 5mm olive, try buying one, its impossible :(
Vehicle: 75 Cruiser
Post Posted: Fri Oct 06, 2006 11:01 am
bump...
ay royce, can you get some line and fittings for me? :)
I just need one line.
Post Posted: Fri Oct 06, 2006 11:20 am
oh yeah thats right
Post Posted: Fri Oct 06, 2006 12:53 pm
got em :wink: even found some metal quick release fittings out there that I'd never seen before
for those that are interested, the little adaptor bit on an airlocker that screws into the bulkhead fitting that the hose then attaches too is 3/8" UNF thread
a normal brass compression fitting for 3/16 nylon tube os also 3/8" UNF :wink:
so if you get a brass fitting to join 2 3/16" tubes together and one for 3/16" tube to 1/8"BSP you can change to more common 3/16" nylon tube on airlockers, which is about $1 a metre not $55837575 from ARB
or 3/16" tube to whatever BSP will give you a normal bsp fitting on your diff to run whatever hose you want :)
Vehicle: 75 Cruiser
Post Posted: Fri Oct 06, 2006 1:32 pm
the only bit i understood was that you got them :oops:
I'm putting the diffs in the white suzi. I put the compressor in yesterday.
Post Posted: Fri Oct 06, 2006 1:42 pm
just nod and pretend, thats what everybody else is doing :wink:
theres enough to do both diffs I reckon, I spose you need some thread tape too :roll:
Post Posted: Fri Oct 06, 2006 3:21 pm
parting out the LWB? I'll give you $100 for the rest of it :)
Vehicle: 75 Cruiser
Post Posted: Fri Oct 06, 2006 3:25 pm
nope! (not yet)
I just thought there's no point having air lockers sitting in it being wasted. (so i took the front airlocker out and put the auto locker in it hehe)
All the good stuff will be on the white one until the lwb is up and going, which could be years. I'm not in any rush now.
Post Posted: Fri Oct 06, 2006 3:49 pm
so now the white one has airlockers youll put some longer shackles in just for a bit more lift
then youll fit 31's for a bit more clearence
then put the s3 in cause its there
then youll need an exo to stop it getting smashed up
elmo MKII :)
I think you should trade the white one on a vitara :wink:
Post Posted: Fri Oct 06, 2006 4:31 pm
elmo MKII :)
Everything you said was right until you got to the last sentence :wink:
Post Posted: Fri Oct 06, 2006 4:37 pm
theory being he then has a girls car he cant take off road, thereby forcing him to get the LWB finished :wink:
Post Posted: Sat Oct 07, 2006 12:37 am
SneakiIt all makes sence to someone that owns a Vitara or two.
Steve W
Users browsing this forum: Google [Bot] and 20 guests
