It is currently Thu Oct 01, 2026 6:31 pm
Post new topic Reply to topic  [ 57 posts ]  Go to page 1, 2  Next
Post Posted: Mon Mar 10, 2008 10:34 pm
How hard is it to remove and if need be refit leaves??? :?
[quote="royce"]hmm ok havent been there for a year
Post Posted: Mon Mar 10, 2008 11:40 pm
easy
Post Posted: Tue Mar 11, 2008 12:04 am
:goodjob:
Post Posted: Tue Mar 11, 2008 12:18 am
g clamps on spring, undo bolt in middle, remove leaves, do bolt up and refit
Post Posted: Tue Mar 11, 2008 3:21 am
Yeah piss heasy dudedon't even have to take the spring out some times. If your spring retaining clamps are already open just jack the car up till the tyres are pretty much just off the ground then unbolt the u bolts and you can unbolt the spring pack and take some leaves out then bolt it back together. the zook diffs are light enough to manouvere about.
Post Posted: Tue Mar 11, 2008 5:04 pm
Did you get all that Andrew, lets do it! :lol:
Vehicle: 75 Cruiser
Post Posted: Tue Mar 11, 2008 5:29 pm
We'll chop the back off the car while we're at it Andrew :)
Post Posted: Wed Mar 12, 2008 12:00 am
yep, got all that. sounds easy enough. don't know about chopping back off steve. would look pretty sweet though. :lol:
andrewa.
Post Posted: Wed Mar 12, 2008 12:36 am
Yeah,just do it,ASAP that sierra's beggin for it,I'da done it the day I bought it! If the swaybars also fall off at the same time it wouldn't necessarily be a bad thing either(even if only for a trial).While you are there pull the springs off and apart (undo centre bolt and clamps) and wire brush between leaves where they slide.Check the centre bolt and replace if needed at reassembly (minus 2 leaves).
Post Posted: Wed Mar 12, 2008 1:20 am
yeh i know. it's like sitting on cement. sway bar has been off for ages & i'll be changing back to std shackles aswell. :rambo:
Vehicle: Zookless
Post Posted: Wed Mar 12, 2008 2:01 am
What brand of springs are they Andrew? I've been thinking of removing a leaf or two from mine for a while. They are Dobbinson springs are really stiff.
I'll be interested to see how you go.
Post Posted: Wed Mar 12, 2008 2:51 am
dobinson springs aswell. 6 in front & 5 in rear. & yes they are quite stiff. i'll let you know how things go once done.
Post Posted: Wed Mar 12, 2008 9:16 pm
6 in front! Holy crap I run 3 in front but they only came with 4 front and 4 rear
Post Posted: Wed Mar 12, 2008 11:58 pm
No wonder it's so stiff try losing 3 front and 2 rear,don't cut cut back the U-bolts or centre bolts till you find out what works it'll be worth the time an effort to experiment,and at least it won't cost anything.
Post Posted: Thu Mar 13, 2008 12:12 am
OME have that many leafs, theres more to it than qty, thickness and spring camber play a big part
most I have found start with 1 small leaf and if its still too stiff put it back and remove the next biggest and so on till you get it
dont go too soft either or they will sag pretty quick
Post Posted: Thu Mar 13, 2008 12:42 am
thanks for all the input guys. will take on board & see what i come up with.
andrewa.
Post Posted: Thu Mar 13, 2008 2:05 am
Royce has a point especially concerning sag which may take time.
Vehicle: Zookless
Post Posted: Tue Mar 25, 2008 1:22 am
How did you guys go?
I pulled a leaf out of my rear springs today, 2nd from the bottom. I only went for a quick drive to the bottle-o, but it didn't seem to make much difference.
I will pull one out of the front tomorrow and see how it goes.
Here's a pic of the rear pack with 2nd from bottom removed. I'm thinking maybe I should have just pulled off the bottom one only?
Post Posted: Tue Mar 25, 2008 1:45 am
Hey CairnsZook, we did this to a mates zook over the weekend too. He's got a set of HD Dobinson's, and they are pretty hard. Pulled the 2nd from the bottom too and the pack sits down on the overload now. He said it rides better but I think that overload will kill the flex. We'll see...
I would try as you say to put the 2nd one back and pull the bottom one. Only thing about that is you might start wrapping those springs up if you give it a bootful.
Vehicle: Zookless
Post Posted: Tue Mar 25, 2008 2:29 am
Yeah will do Damo.
I don't reckon I'll have any worries wrapping springs with stock engine, 29's and 4.16 gears.
Post Posted: Tue Mar 25, 2008 3:05 am
CairnsZook wrote:
Yeah will do Damo.
You might be suprised, especially with 4.16's. Watch someone's leaf springs when they hammer it off the line. I do suspect you'll be OK though, just something to be aware of.
Damo.
Vehicle: Zookless
Post Posted: Tue Mar 25, 2008 3:24 am
What do you reckon for the front pack? Which leaf did your mate remove? I currently have 5 leaves and an aluminium bullbar.
Post Posted: Tue Mar 25, 2008 1:00 pm
We didn't remove any from the front yet. I think he has a 5 leaf pack too, but has a steel ARB front bar. I'm not sure if we're going to pull a leaf from the fronts or just go RUF.
Vehicle: Zookless
Post Posted: Tue Mar 25, 2008 9:51 pm
I've pulled out the 2nd from the bottom on the front, and she rides heaps better now. The front hasn't lost any height either.
In the rear end I swapped the bottom 2 leaves, but it still doesn't flex as well as the front. I think I'll pull another one out of the rear and see how that goes.
Post Posted: Wed Mar 26, 2008 5:12 am
The trade of in the back is load carrying, but I guess it's a matter of finding that happy medium huh. I might hit Ben up to do the same in the front as you.
Post Posted: Wed Mar 26, 2008 11:07 am
be careful going too soft in the rear, tends to make them lean back and wheelstand up hillclimbs
Post Posted: Wed Mar 26, 2008 4:13 pm
sorry about the highjack but when you say rear up front do you mean as in rear springs up front or rear diff up front. i am a little confused on the matter :oops: yeah i know.... bloody idiot!
thanks
Web wheeler extroadinaire
Post Posted: Wed Mar 26, 2008 8:43 pm
thanks
We're just talking stock springs at the moment. Well, at least I am! :oops:
Vehicle: Zookless
Post Posted: Wed Mar 26, 2008 9:31 pm
Actually, mine are 2in lifted heavy duty Dobbinson springs. That's why they were so stiff. :lol:
Pubic - RUF is putting rear leaf springs under the front end. Can be done by re-drilling the rear spring perch a little further back and fitting a longer shackle. This will result in the front diff being in about the same position.
It can also be done with a chassis extension, which will move the front diff forward around 40-50mm, allowing clearance for larger tyres.
This is the way I will go - eventuallly :roll:
Post Posted: Wed Mar 26, 2008 10:45 pm
thanks muchly... all makes a little more sense now.
Users browsing this forum: Google [Bot] and 102 guests
